DIY Beolab 4000 table stand
This post has 8 Replies | 0 Followers
matador43
Posts 1,373
matador43 Posted: Fri, Jan 5 2018 3:42 PM
Hi Alls,
Following my question in this thread (and thank you to all of you who tried to help me…)
Beolab 4000 Table Stand Alternative… -
I decided to find a solution by myself. It ended in a little DIY project I wanted to share in case it may help anyone. So here we go.
It start with a simple Ikea item:
matador43
Posts 1,373
Remove the top border just under the littles pieces who look like cat ears.
Use a blade. The plastic can be cut pretty easily!
matador43
Posts 1,373
I made a guide with a 13° tilted square box with a front border matching the height of the band under the Ouverture.
I printed it on a sticker paper and sticked it on a piece of cardboard. I used it to mark the Trofast:
matador43
Posts 1,373
And then cut it:
matador43
Posts 1,373
After that i cut the top border as an arc matching the back of the BL 4000.
matador43
Posts 1,373
Now it need a little sanding to clear the borders and cleaning the pencil lines, and here it is !
matador43
Posts 1,373
Stability is good but could be enhanced with some additional work.
1,50€ + 30 min work each.
Hope this help…
Tucker
Ponte Vedra Beach, FL, USA
Posts 439
Tucker replied on Fri, Jan 5 2018 4:08 PM
Brilliant!  I love this!!!
-Tucker
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000,  Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
Earle
Posts 223
Earle replied on Fri, Jan 5 2018 4:38 PM
you know,.... if you laid the stand on a table covered with a silicone sheet, and poured acrylic into what you effectively made as a mold, and put the BL4000 on top (covered in cling film of course), you'd end up with clear solid stands. Don't forget to spray the inside of the mold with silicone spray too though, so that it comes off when cured.
**Forgot to mention, after that, you could easily drill holes for cabling.
Page 1 of 1 (9 items) | RSS
