Good evening one and all,
I have inherited a beovision 6 on moving into my current address. It is paired with a Beo4 remote. Despite the power light on the screen being red and occasionally green when attempting to switch the tv on, all I'm getting is the red light and a blank screen.
I have checked the batteries in the remote and it appears to be in working order.
I have switched the mains off and on removing the motorised stand cable and replacing same with no effect.
It is a stand alone tv with just a set top box. It had been working fine, then as described above.
Any ideas?
Thanks in advance.
