Beoplay A6 and Google Chromecast
This post has 13 Replies | 2 Followers
DavidSJones76
Posts 39
DavidSJones76 Posted: Sat, Jan 20 2018 1:46 PM
Hello,
I have a set up of 3 Beoplay A6's, 2 Beoplay M5's, a Beosound 2, and 2 Beoplay M3's.
The problem I have is that none of the A6's show up when trying to play via Chromecast. All the other speakers show up, it is just all three of the A6's.
I have all my speakers enabled, with Chromecast working on them all, apart from the A6's. So, I don't think it's anything to do with that.
I hope someone can help me here please.
Thank you.
David
  • Filed under:
Ulrike
Germany
Posts 174
Ulrike replied on Sat, Jan 20 2018 3:13 PM
David,
if you don't have Chromecast related Wi-Fi issues ask B&O support to activate another Firmware version for your Beoplay A6. They released FW 1.15.17640.17856519 in December, which disables Google Cast. Having no Wi-Fi problems at all they activated FW 1.15.17881.16477003 for me, thus Google Cast is enabled again and works fine.
Chromecast issues further reading:
https://support.google.com/chromecast/answer/7634752?vid=0-1160194496130-1516208028507
DavidSJones76
Posts 39
Hey,
Thank you so much. That's very helpful. Just one question though...how do I contact B&O support to ask them to activate Google Chromecast for me?
Thanks again for your help. It's much appreciated.
David
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Jan 20 2018 4:02 PM
bogo@mailgb.custhelp.com
Ulrike
Germany
Posts 174
Ulrike replied on Sat, Jan 20 2018 4:06 PM
https://www.beoplay.com/countryselector
Ulrike
Germany
Posts 174
Ulrike replied on Sat, Jan 20 2018 4:27 PM
David,
since you also have a Beosound 2 and can compare to A6:
What do you think, does it make sense to replace the A6 with a BS2 for better sound quality ?
Ulrike
Germany
Posts 174
David,
DavidSJones76
Posts 39
Hey,
Thanks for the links guys. Ill look in to asking them for an update to allow Chromecast on my A6's.
As for the Beosound 2 question. I do feel it is a much more superior speaker to all my other ones, including the A6.
Just to give you an idea, I have two A6s on one wall in my Living Room and the other side of the room, I have one Beosound 2. The Beosound 2 has a better quality sound than the two A6's put together. So, I would definitely recommend it.  Though the A6 is still good quality, in my opinion.
I hope that helps your decision.
David
Ulrike
Germany
Posts 174
Ulrike replied on Sat, Jan 20 2018 4:56 PM
David,
that's what I assumed.
So thanks a lot for your clarification, going to get the BS2 now ...
alvinhctan
Posts 8
Hi Ulrike,
My auto software update is not working for whatever reason. It keeps saying the 1.15.17640.17856519 is the latest version. I spent 3 hours talking to B&O support today, trying to update my firmware with no success. Do you have a copy of the 1.15.17881.16477003 firmware handy? The Beotool App shows latest firmware to be 1.20.30100.247491601.
Regards,
Alvin
alvinhctan
Posts 8
Hi Ulrike,
Regards,
Alvin
Sweden
Posts 357
Silver Member
Martin replied on Wed, Apr 3 2019 5:36 AM
I have two A6s. One of them updated yesterday to 1.20 software. The other will not update to new software for some reason. It still has 1.19 and says that software is up to date. If I use BeoTool it says there is new software for the A6. I have tried to reset to factory but it did not help. After factory reset I can not login to Deezer or tunein either. Does someone know What to do or What is wrong with my A6?
best regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Aussie Michael
Melbourne, AU
Posts 3,730
Martin:
best regards
Beovision Eclipse 65 with floorstand (from STB Brackets), Beolab 5 front (sw 3.30a), Beolab 3 rear, 2xBeoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K
Did you reset to factory on the app or press the button underneath?
I had this with my BS1 at one point and i pressed the button down the bottom (the one with the little cog shape next to it) and reset it that way.
Only one time have i had to remove it from my beoapp and then press the button and then reconfigure it all together. Then it said it had an update.
Sweden
Posts 357
Silver Member
Martin replied on Sat, Apr 6 2019 6:15 AM
Hi
I called support and they pushed the sw update manually. Now everything works as it should.
best regards
Page 1 of 1 (14 items) | RSS
