Hi, could anyone tell me what the difference is between the Beoplay S3 and the new Beoplay M3?
Other than looks the S3 seems to have a slightly larger woofer (4" vs. 3.75") and is half the price of the new M3.
Which one is better (sounding)?
Thanks!
The S3 is a bluetooth speaker.
The M3 is a very versatile sound system (including AirPlay, built-in Tunein.....and also bluetooth, which is NL compatiple (means working with other B&O network link products.
Two rather different products.
As for ‘Better sounding’, you would have to judge for yourself....
....listening at best in the place, where you would have them.
P.S. A bit of googling could have told you this ;-)
Anyway welcome to Beoworld.
M3 great for multi room and wifi.
S3 is a basic Bluetooth speaker.
S3 produces a better sound I believe. Much better bass than the m3
the S3 is so cheap because I think stores refused to stock them so they were offloaded cheap everywhere
