Could it be you are looking in a Beovox S80.2 manual?Beovox S80 and S80.2 are actually quite different. Capacitor kits are readily available (for both types).
Grab the metal basket and press with both thumbs on the plastic ring.It binds immensely but will come off if you just keep pressing.It doesn't break that easily.
Just a caution when using the Mundorf caps, they always measure higher than their specified values. Say you have an original 25uF then the Mundorf 22uf will be just fine. However when you go up to 50uf, you need a Mundorf that will measure about 8uf lower. They certainly not within the 20% spec!
