Options for rear speakers in 5.1 setup
This post has 11 Replies | 1 Follower
rxcohen
New York
Posts 201
rxcohen Posted: Mon, Jan 22 2018 5:42 PM
I currently have BV11-55, BL1s up front and BL19 subwoofer. Thinking of side/rear speakers to get a full 5.1 experience. Any recommendations? I am not sure what characteristics I should be looking for based on their limited functionality and the need to interact/complement BL1s. Also given my limited space, the speakers would have sit next to the sofa (as opposed to behind), if that makes any difference. BL17 seems to be the only option from the current line up, but wondering if BL4, BL12-1/2/3 if i could score some slightly used speakers would be decent options. Also, can you add non-BO to the mix? Thanks in advance....
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
trackbeo
Posts 644
trackbeo replied on Tue, Jan 23 2018 6:32 AM
BeoLab 3's apparently work well -- check out this post showing a tight layout similar to what you describe:
http://archivedforum2.beoworld.org/forums/p/227/233889.aspx#233889
elephant
AU
Posts 8,219
elephant replied on Tue, Jan 23 2018 8:07 AM
I currently use BL4s as rears on either side of the couch
Suits me but others complain they are intrusive Surprise
My plan is to upgrade the rears to BL3s to get more bass
Which will get more complaints Big Smile
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Tue, Jan 23 2018 8:12 AM
Actually for clarity our couch arrangement is a U
i.e. .|_|.
And I sit along the _ and BL4s are the .s
BeoNut since '75
Brian
London/Aarhus
Posts 219
Brian replied on Tue, Jan 23 2018 9:46 AM
I used BL3s as rears with my previous BL1s at the front. worked well.
Aussie Michael
Melbourne, AU
Posts 3,730
Brian:
BL3s are good as rears.
You can also make a music speaker group on your BV11.
And as it is WISA you can make the BL3 wireless.
Aussie Michael
Melbourne, AU
Posts 3,730
rxcohen:
3 As rears
Millemissen
Flensborg, Denmark
Posts 14,680
I’d say, it depends on your placement options.
If you must wall-mount them go for the BL3’s - be sure to turn them downwards to the listening area.
If you have enough space beside the sofa, a set of BL6002 would be fine - would fit well designwise, too.
Your BL19 is fine for serving front and surround speakers with bass (if well setup).
rxcohen
New York
Posts 201
rxcohen replied on Tue, Jan 23 2018 2:09 PM
Thanks everyone for the input - BL3s seem to be the winner here. I have a WISA transmitter so can always pop a couple of receivers to avoid cabling back to the TV. Separately, i am still amazed by how much value the BL19 has delivered to a 3.1 setup, and specially for stereo music. Cheers, Robert
Brian
London/Aarhus
Posts 219
Brian replied on Wed, Jan 24 2018 9:31 PM
Nice Cobra lamps Michael - got two myself albeit white shades :)
Aussie Michael
Melbourne, AU
Posts 3,730
Brian:
Aussie Michael
Melbourne, AU
Posts 3,730
rxcohen:
Nice move
Remember that i think the BV already has a built in transmitter (from memory) so you shouldn’t need to use your transmitter 1 (just the receiver 1s)
Page 1 of 1 (12 items) | RSS
