Beogram 9500 issue
This post has 5 Replies | 0 Followers
mounin
Posts 13
mounin Posted: Mon, Jan 22 2018 7:14 PM
Hi everyone, I'm coming to you because I've a problem with a Beogram 9500 that I just baught.
it sounds bad (crackly, and tiny), so I replaced the mmc2 with a good one thinking it was the cartridge/ needle... But it's the same with the good one .
other thing, the motor does a weird noise ... Is it related? (Noisy motor, bad sound ?
i plugged it into my beocenter 9500...
thanks by advance
sonavor
Texas, United States
Posts 3,732
sonavor replied on Tue, Jan 23 2018 1:21 AM
On B&O turntables without a built in RIAA phono preamp the audio signal goes directly from the cartridge out through a muting relay to whatever amplifier/receiver you are using. For that type of scenario I would recommend switching the phono cable between the turntable and amplifier/receiver first. If the problem isn't there start looking inward at the DIN plug and muting relay.
Your Beogram 9500 probably does have a built in RIAA preamp though so that is an added suspect to the problem. I would still try a different cable first but after that you will need to start debugging the internals. At least it appears likely your MMC2 is good.
I would guess that the motor issue is a separate problem.
-sonavor
mounin
Posts 13
mounin replied on Tue, Jan 23 2018 10:52 PM
Thank you for the answer, I think stock 9500's don't have riaa preamp, do you think that this one has been modified?
best regards
beoaus
Posts 177
beoaus replied on Fri, Jan 26 2018 2:48 AM
Not that it helps, Beogram 4500’s have the inbuilt RIAA. The 9500 is pretty much the same sans this component.
Beoaus.
mounin
Posts 13
mounin replied on Fri, Jan 26 2018 12:47 PM
I think the same... so, i have to check the cable...
Any other ideas for this weird problem?
Beat regards
mounin
Posts 13
mounin replied on Sun, Feb 18 2018 11:26 PM
Good News ! The turntable run correctly plugged into a beomaster 4500 , so it was the riaa problem.
I have to try it into the beocenter 9500 plugged into another input instead of phono for a final test.
But, it still does the weird noise. I'm not sure but it seems like it comes from the motor... A kind of a "tic tic tic" rapidly...
Any ideas for this issue?
thank by advance to everyone,
Page 1 of 1 (6 items) | RSS
