Hi All,
Just wondering if anyone can help at all, I am in the process of restoring a Beocenter 4000 type 1603. I have recapped the amps and psu with new caps and its been reccomended I change the pots on the output stages I have some on order but I cannot seem to find on my circuit drawings what the voltage should be, just wondering if anyone can help as I dont wanna blow it up!!
Thanks,
Lewis
Look in the servicemanual under adjustments.Start with the trimmers in center position and adjust from there.
