How to connect motorised stand to MX4200?
This post has 11 Replies | 0 Followers
sapphirekhin
Posts 4
sapphirekhin Posted: Thu, Jan 25 2018 1:49 PM
I have the motorised stand from MX7000 and I was trying to change the baseplate and get install into my MX4200. Upon closer look, MX4200 have different STAND port which is like 5pins DIN (meanwhile the MX4000 is 4Pins DIN). The cable from stand could not be hooked up into this STAND port on MX4200. How should I hook up the motorised stand cable into the MX4200 STAND port?
https://imgur.com/a/7MVg4
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Jan 25 2018 3:46 PM
As far as I know you can't. The interface is different electrically as well.
--mika
sapphirekhin
Posts 4
So i need to get a motorised stand that specifically designed for MX4200? or that there is no motorised stand for MX4200 model at all
JKW TAYLOR
Nederland
Posts 140
JKW TAYLOR replied on Fri, Jan 26 2018 10:04 AM
The motor unit (5 pins) is the same  for a MX4200  and MX8000
The stand for a MX4200 is de same as a mx3500 mx4000.
Ken
JKW TAYLOR
Nederland
Posts 140
JKW TAYLOR replied on Fri, Jan 26 2018 10:06 AM
And MX4002
Ken
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Jan 26 2018 10:07 AM
Yes. I believe MX8000 uses the same stand interface as MX4200. But this is all from vague memory, I've never had any of these last model CRTs myself.
--mika
tournedos
Finland
Posts 7,357
Ken beat me to it. Yes - thumbs up
--mika
VANTAGE
Posts 88
VANTAGE replied on Fri, Jan 26 2018 11:35 AM
I had an MX4002 years ago, which I loved. I believe the motorized stand was B&O type no. 4116.
Current: Beovision Eclipse 65" v1 - Beolab 50 - Beolab 28 - 2 x BS2 (GVA) - 1 x BS1 (GVA) - Beoremote Halo - H9i
Past:
Beovision MX4000 - Beovision 3-32 - Beovision 7-55
Beosound 9000 - Beosound 5 / Beomaster 5
Beolab 6000 - Beolab 8000 - Beolab 5 - Beolab 3 - Beolab 17
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Jan 26 2018 12:00 PM
Reading this whole thread again, the information is still a bit ambiguous. So, just to recap:
  • MX4002 is basically an MX4000 with Masterlink interface. They share the same 4-pin stand interface as earlier models (up to MX7000 in the bigger form factor).
  • MX4200 and MX8000 are internally very different from earlier models. They both use the later (and incompatible) 5-pin stand interface.
--mika
sapphirekhin
Posts 4
Can someone point me to the right direction where I can somehow adapt 4pin to 5pin so that I can use my current motorised stand for my MX4200? If not, anyone on ebay selling the motorised stand for MX4200? Thanks
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
The motors are completely different electrically and cannot be modified.
Regards Graham
Level42
Posts 3
Level42 replied on Sat, Jul 21 2018 9:57 AM
This is not true. The motors themselves ARE compatible, the surrounding electronics are different.
I found info on internet from a guy who exchanged the motor from a MX4000/7000 stand to a MX4200/8000 stand.
Page 1 of 1 (12 items) | RSS
