Beovision 8-40 Masterlink module?
This post has 34 Replies | 0 Followers
Master123456789
Posts 237
Master123456789 Posted: Thu, Jan 25 2018 7:40 PM
I have bought a beovision 8-40 without a Masterlink module. If I buy a Masterlink module, is it just plug and play? 2 screws of and set it in?
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
I think your bigger problem is finding a Masterlink module to buy..
However, if you do find one the diagram below should help
Regards Keith....
Master123456789
Posts 237
Ah looks simple on this diagram. That is just plug and play.
Master123456789
Posts 237
No software Update?
mbee
Paris, France
Posts 1,842
mbee replied on Thu, Jan 25 2018 9:22 PM
If there is no software update to do on a non-masterlink BV8, I've got a spare module almost brand new...  (just tested that it worked the same that my current module, and sadly, the faulty thing in my BV8 is not this module). But I suspect high shipping cost from France
Master123456789
Posts 237
I have paid 100 euro for my bv 8-40, so I think it maybe will cost to mutch. I will try to ask here in dk.
I have a bv8-32 and a bv8-26 with Masterlink module. Can I use that?
Master123456789
Posts 237
Nobody knows if a can use a Masterlink module from the 32 or 26 inch??
mbee
Paris, France
Posts 1,842
mbee replied on Fri, Jan 26 2018 10:12 PM
No, these aren't the same modules. Maybe the BV10-40 module is the same as the BV8-40.
egj1975
Posts 5
egj1975 replied on Sat, Jan 27 2018 2:33 PM
BV8 40 and BV10 40 MK1 and 10 46 MK1 use the same ML PCB but the metal frame that the PCB is mounted in are not identical.
Master123456789
Posts 237
Now I got a masterlink module for 28 euro, called system board. I got it in a few days. Then it is just to plug it in?
Master123456789
Posts 237
No experience around that in this forum?
mbee
Paris, France
Posts 1,842
mbee replied on Sun, Feb 4 2018 6:39 PM
Yes, plug... and play!
Master123456789
Posts 237
So nice - thank you - looking forward to that! :-)
Master123456789
Posts 237
Now I have set the module in my bv8-40. It does not work. Maybe it is the option-setting at the tv? Any other ideas? I have taken a picture from the service meny.
Master123456789
Posts 237
kai
Posts 362
kai replied on Sat, Feb 17 2018 12:34 PM
Looking at the screenshot you have option, if you are using bang and olufsen hi-fi you need to make it option 2
Master123456789
Posts 237
I will try that. But what does the SM HW mean? Does that mean anything?
Master123456789
Posts 237
Does somebody know if this module is installed correct? Can somebody verify? :-) Thank you Cool See my picture earlier at this day
elephant
AU
Posts 8,219
elephant replied on Sun, Feb 18 2018 8:02 PM
Master123456789:
https://archivedforum2.beoworld.org/cfs-filesystemfile.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.75.87/IMG540560520.jpg
Here is mine
SM HW also n/a
But build level quite different
BeoNut since '75
Master123456789
Posts 237
Thank you for the picture. Good to see.
Do you know what Build level mean? Why is it with red by mine?
elephant
AU
Posts 8,219
elephant replied on Sun, Feb 18 2018 11:01 PM
Master123456789:
I thought you had photoshopped it red !
No idea but maybe it is a clue ?
When mine was installed I had B&O technicians do it ... and I am sure they did a firmware upgrade.
Are you near a B&O shop with service people ?
BeoNut since '75
Master123456789
Posts 237
I must do it by myself. It is to expensive to let technicans do it. I have payed 100 euro for the bv 8-40. Smile
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Feb 19 2018 12:54 PM
"Build" is a reference to what firmware version is installed.
I recall that red color is an indication that an upgrade have failed of some reason.
When a technician tried to upgrade a BV10 I had a number of years ago, the build number went red after he tried to upgrade with the servicetool. After another try the upgrade was okay.
Millemissen
Flensborg, Denmark
Posts 14,680
Master123456789:
Nothing you can (easily) do yourself (unless you have access to the B&O service tool....and know what to do!)
However, if you only paid 100 € for the tv, it should be worth it to let a B&O technician finish the job.
If you want, he could also load the PUC codes for external devices of your choice.
And the DVB-tuner needs an update, too.
Master123456789
Posts 237
well, 200 euro for a technican is to expensive. Maybe a factory reset can do it? How do I do a factory reset?
and also, I can turn out all devices with the masterlink and also I gives power to my masterlink system (as an audio master). Something works!!
elephant
AU
Posts 8,219
elephant replied on Thu, Feb 22 2018 10:48 AM
I recommended getting a service guy in.
I had mine done in 2012. From memory it took them some time, including the use of a computer plugged into the BV.
As MM said, they can also load the PUC drivers you need st the same time.
Have you looked at your existing PUC list ?
Is there anything you need that is missing?
BeoNut since '75
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Feb 22 2018 11:17 AM
Master123456789:
As far as I remember:
Press Menu
Highlight Options/Settings
Press Menu 0 0 GO
This should bring you into the service menus.
Look around there - but don't change any numbers.
For me 200 Euro would be too much to spend on a TV that is worth a lot less, too.
Ralf
Master123456789
Posts 237
"Reset all features" - is that factory reset? and can I just push that without any "danger"?
CasperI
Posts 93
CasperI replied on Sun, Feb 25 2018 8:02 AM
Your problem is, that the System Module SW doesn’t match the rest of the TVs SW versions. That is also why the Build number is red - there is a mismatch.
When the rest of the SW is from Build 166d the System Module SW have to be version 20.06o to match it.
That being said, it wouldn’t hurt to get the whole TV updated to a later build.
I do doubt that a local store would charge you 200 euro for an update. Especially if you can bring the TV to the store.
Master123456789
Posts 237
Very interesting. Thank you - for the better understanding. So if the versions where right, it would be better. Maybe it is earsier for me to buy another bv 8-40 where the masterlink module allready are build in.
I have to talk with a B&o store about my BS essense, maybe I can ask them there. You think it would be ever more expensive?
CasperI
Posts 93
CasperI replied on Sun, Feb 25 2018 10:58 AM
A simple SW update should make everything work properly.
I think they would charge less. Where in DK are you located ?
Master123456789
Posts 237
Interesting. I live in Copenhagen Smile
Master123456789
Posts 237
maybe you know someone who can help?
Ralf
Hamburg Germany
Posts 189
Ralf replied on Tue, Mar 6 2018 3:22 PM
I had a similar issue (Build number red) but ML works.
I wrote to Beocare and they told me, the build always has special sofware for the SM included, there is a mismtach, but the SM should work in daily situation, whatever this meant :-)
The actual SM SW is 50.x. for Build 229. If I am right the 166d and 20.05 should work together. The SM Modul SW entry could be red as well, even in that case it should work.
What error do you have? There are many configuration options and you shold always unplug your whole ML system from mains for 30 seconds, then install all cables and plug everything back to mains. The LED on your BV turns green for 10 seconds and checks for other ML equipment.
Give B&O a try, ask them for a update, i carried my BV8-40 to the local Beostore in Hamburg and could wait for the update. It took only 15 Minutes and was 25 Euros.
Ralf
PS. You should update the HD Software to 0.1.9.9 this could be done by yourself: Download from B&O and put it on a USB Stick.
Zazouzt
Near Strasbourg France
Posts 222
Zazouzt replied on Wed, Jan 16 2019 8:56 AM
could i know where you got the masterlink module ?
I'm looking for one too.
Zazou
Page 1 of 1 (35 items) | RSS
