In the manual its mentioned i can with a particular model get sound over to the pair of active speakers if i have one of those beosound cd players, is it some certain models or how does it work? if i ever get one of them, what should i do and how?
Sorry, do you mean ‘a BeoSound with a built-in cd-player’?
Like the BeoSound 3000?
It is in that model range im thinking off, i read in the owners manual if you had a beosound, it was possible to play the audio over it.
I guess, that you probably mean, that you can play the sound from the tv/the MX8000 over the speakers,
that are connected to the BeoSound.
Am I right?
If so, it is correct, if both systems have a MasterLink module and the are connected with a ML cable.
Please give me some more information on the BeoSound and the tv.
N.B. If it is easier for you, you may also write in danish or ask your question here:
http://archivedforum2.beoworld.org/forums/18.aspx
