Hello all.
As far as i know the Oppo blueray players have two hdmi outputs. Is it possible to use the beosystem 3 to drive my beolabs and use the second hdmi output from the oppo to feed a 4k hdr tv?
if possible i plan to use a lintronic box to controll it.
Format 0 😀😎
I have the BeoSystem 4 with an Oppo UDP 203 4K blu-ray player and that is how I have mine setup. I also have a 4K Apple TV connected to the HDMI In on the Oppo player so the blu-ray acts as a switcher. It works great but the only thing I lose is the on-screen display when I change the volume on the BeoSystem 4, but that is not really a problem. Sometimes I would like to know how loud I have it turned up though!
Great news. Thanks for the quick reply.
do you use the Lintronic box as well?
I use a Harmony remote. It works ok, but not as good as I would like.
