I have bought a Beovision 7-32 type 9331 so already standard HD-ready. The image I find very "soft" and and red is to strong It is less sharp than I think it could be. Now there are a lot of image settings in the service menu. See pictures. Someone tips what I could adjust to make the colors more pronounced, dim the red and get a sharper image?
Kind regards, Edwin
BV 7-32 Service menu picture.jpg.aspx
BV 7-32 Service menu.jpg.aspx
I downloaded the service manual from the internet but I read there that during calibration you should offer images on the screen via scart on V-tape to be able to do the calibration of the colors. Does anyone have a DVD with these images?
Kind regards Edwin
Same Issue here, did u find a solution?
