Beovision 7 40 Mk 3 Motorised Stand Operation
chrislb
Posts 4
chrislb Posted: Sun, Jan 28 2018 2:21 PM
Hi All - I have just inherited my fathers B&O TV and system - very cool!
I cannot seem to get the motorised stand to work - I have plugged it in and the remote 4 does not show stand in  list? so I cannot adjust angle ? Any ideas - thx Chris
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sun, Jan 28 2018 2:27 PM
Well, if you plugged the stand in whilst the TV was powered up, you could have blown the module in the TV - which means a new chassis. B&O should make more of a thing of not doing that..
If it was powered down when you plugged the DIN plug into the rear, do the following.
1) Power everything down.
2) Disconnect the stand
3) Reset the TV to factory default settings
4) Power down again, and wait a minute or two.
5) Connect the stand
6) Power up - and it should recognise the stand.
If it doesn't work, try doing that sequence a few more times. Usually the TV gives in and plays ball.
Lee
chrislb
Posts 4
chrislb replied on Mon, Jan 29 2018 10:49 AM
Thanks Lee - that worked but now the surround speakers which were working are not functioning? Its incredibly complex! Thx Chris
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Mon, Jan 29 2018 11:02 AM
Because you reset the TV, you reset the speaker configuration. Don't worry - it can be fixed with a few button pushes Smile
Go back into settings and tell the TV it has surround speakers.  If you have the user manual it will tell you exactly what to do.
Lee
DISCODUCK
Posts 14
DISCODUCK replied on Sun, Mar 22 2020 3:34 AM
Hi Lee.This is not working for me.Not just on one,but 3 x beovision 7-32's with the speaker etc.
Tried everything you suggested incl factory reset but getting nothing,not a jot from the stands,
I saw 2 of the three stands work and turn etc when collected but now when reconneceted,absolutely nothing.No stand references coming up in the menu at all.Am I missing something? Thx.Alan
archisarto
Posts 1
archisarto replied on Thu, Nov 11 2021 11:55 AM
Hi Lee,
Just asking, how do you reset the TV ?
I have a BeoVision 7 32" and I can't find the reset button.
Thank you for helping !
Page 1 of 1 (6 items) | RSS
