hi,
i have a system with a beosystem3, beomedia1, ml Gateway and would like the Net.Radio to work, but I need an audio master.
i think I read that a Beolink Converter type 1611 connected in will do the job. Does that mean I just connect it into the ML network and power it up, and i’ll have an audiomaster - so net radio will then work? I don’t need any other connections on the 1611?
In dutch:
Om N.MUSIC en N.RADIO vanaf BeoMedia 1 te kunnen verspreiden naar audio en videobronnen in de secundaire ruimten, is een N.MUSIC / N.RADIO compatibele audiomaster vereist, d.w.z. BeoSound 3000 / 3200 / 9000 / BeoCenter 2 /BeoCenter 1.
In other words, you need a real audiomaster in your system, a 1611 will not help you!
That’s a pisser. Thx
