Beoplay firmware
This post has 5 Replies | 0 Followers
Paul cheacker
Spain
Posts 130
Paul cheacker Posted: Fri, Feb 2 2018 1:10 PM
Hi everyone.
after buying a playmaker from ebay for 40 ukl and having a hell of a job getting connected, once I finally solved the issues after two days working on it, I would just like to ask what is the most recent firm ware mine shows 1.00.2485 date 2011.09.11
thks
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Jon
Hampshire, United Kingdom
Posts 241
Jon replied on Fri, Feb 2 2018 2:29 PM
Hi! Does the BeoTool app (should be on iOS and Android) show the playmaker as being up to date or does it say there’s newer firmware available? I’m not sure what the latest version for the playmaker is but BeoTool should show you :)
Paul cheacker
Spain
Posts 130
Hi Jon, ill check it sorry im new to playmaker and the app. Thks
Yendys
Sydney
Posts 312
Yendys replied on Fri, Feb 2 2018 9:29 PM
applemac1:
Just checked mine which I purchased new when they were released and did update the firmware. It is also version: 1.00.2485 but has date 2012.09.11
What’s the issue?
Paul cheacker
Spain
Posts 130
Hi No issue, just didn't know where to find the update Jon explained and now and its up to date although 2012.09.11 is the date guessing they don't update it much.
but this for your reply.
Aussie Michael
Melbourne, AU
Posts 3,730
I found when I first got mine the easiest way to set it up was to plug it in to the router via Ethernet then just use it wirelessly.
Glad to see you have it working ok.
From memory to do updates to the PM you have to plug it in via Ethernet to do them.
Page 1 of 1 (6 items) | RSS
