BeoRemote One and BeoLab 3500
This post has 4 Replies | 0 Followers
Beoberg
Odense, Denmark
Posts 315
Beoberg Posted: Sun, Feb 4 2018 10:58 AM
Hi guys
Just acquired a BeoRemote One. Nice piece of equipment. I have a BeoVision 11 and a BeoLab 3500. I can control the BeoVision 11 just fine. Everything works very well. However, I cannot control the BeoLab 3500 that is linked to the BeoVision 11 via ML/NL converter they way I did with the Beo4. How can I set-up the BeoRemote One to control the BL3500?
Best regards,
Frederik
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Millemissen
Flensborg, Denmark
Posts 14,680
Hej Frederik,
I suppose, that you already have configured the remote for use with an ‘Beo4Audio’ product for using it with the BL3500...
....according to the information in the User Guide.
Is it the BT version?
Soren
Denmark
Posts 115
Soren replied on Sun, Feb 4 2018 12:36 PM
Hej Frederik
you ned to set your BeoRemote one in “Beo4 AV” mode.....
press LIST go to settings (Indstillinger) go to Advanced (avanceret)  go to products (produkter) go to Show (vis) chose BEO4 AV.
Søren
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Sun, Feb 4 2018 2:55 PM
Hi Millemissen. Thank you. Solved the problem. However, I miss the ability to just press volume up to join what source is playing on the BV11 Crying Quite tedious that you have to virtually switch remote in order to join...
Millemissen
Flensborg, Denmark
Posts 14,680
If your BV11 was set to Beo4 operation, that probably would do the trick.
However, you probably want to keep on using it set to be used with a BROne.
Page 1 of 1 (5 items) | RSS
