BeoRemote App for iPad released
This post has 14 Replies | 3 Followers
Vienna
make an educated guess
Posts 1,090
Vienna Posted: Wed, Oct 10 2012 10:42 AM
Just visit iTunes ... Smile
EDIT: works only for BEOVISION 11  as the description in the iTunes Store says ...
elephant
AU
Posts 8,219
elephant replied on Wed, Oct 10 2012 10:52 AM
Vienna:
done :)
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Wed, Oct 10 2012 10:54 AM
elephant:
Vienna:
done :)
now what Smile says ...
PRODUCT NOT FOUND
PLEASE ENSURE THAT THE TV IS
ON THE SAME NTWORK
[FIND]
BeoNut since '75
Vienna
Posts 1,090
Vienna replied on Wed, Oct 10 2012 10:59 AM
Sorry, but you'll need a BV 11 ...
As the description in the iTunes Store says "... for BeoVision 11"
elephant
AU
Posts 8,219
elephant replied on Wed, Oct 10 2012 11:40 AM
Vienna:
so it is not REALLY free then Big Smile
pity ... I hoped it would talk to my ATVs
BeoNut since '75
Yendys
Sydney
Posts 312
Yendys replied on Wed, Oct 10 2012 12:20 PM
elephant:
Good one Ed :-)
kimchr
Posts 170
kimchr replied on Wed, Oct 10 2012 12:49 PM
Did they add an in-app purchase opportunity? 1 BV11 - 10.000 euro. Accept?
Vienna
Posts 1,090
Vienna replied on Wed, Oct 10 2012 1:10 PM
elephant:
Dear friend,
Big Smile We are both old enough to know that NOTHING on EARTH is REALLY FREE!
Sometimes fun will cost your life, sometimes your freedom and in the very best case
just some money ...  LOL
mbee
Paris, France
Posts 1,842
mbee replied on Wed, Oct 10 2012 1:12 PM
As the Beoplay V1 has the exact same engine as the BV11, the future software update of the V1 should give the opportunity to control it with the BeoRemote app...
Vienna
Posts 1,090
Vienna replied on Wed, Oct 10 2012 1:32 PM
mbee:
As the Beoplay V1 has the exact same engine as the BV11...
"Exact" - I seriously Smile doubt !!
Based on the same engine, YES !!
mbee:
Maybe in the future, if B&O wants to PLAY a bit more ...
fishta
Posts 27
fishta replied on Wed, Oct 10 2012 2:10 PM
Wouldn't it be great if B&O offered some sort of adapter for existing TV's. I know there is the ML Gateway but I don'y have an AMX, Crestron or other system so it seems a bit overkill. I have a MK5 BeoVision 7-40 which I consider to be reasonably up to date and would love to control it by my iPad. I am very interested to see this new TV as it may prompt a little desire to upgrade!!
Hero71
Posts 79
Hero71 replied on Sat, Nov 24 2012 11:38 AM
It now also "works" on the Beoplay V1 but this is what I get: http://youtu.be/2QYvahfyMB4 Angry
symmes
Posts 247
symmes replied on Sat, Nov 24 2012 12:03 PM
The app works just fine.
elephant
AU
Posts 8,219
elephant replied on Sat, Nov 24 2012 4:41 PM
Hero71:
On other Apps I see that behaviour when my network access has a wrong password.
What iPad generation are you running ?
BeoNut since '75
CheapB
Posts 53
CheapB replied on Mon, Feb 4 2013 5:55 PM
fishta:
Shouldn't be too difficult to make. If someone with a BV11 or V1 can capture the data stream between the Ipad and the TV from when starting the app to the menu is fully populated I could give it a try. I have the beoremote app connecting to alaptop, but it can only recognize volume, mute and standby functions as the menus are created based the equipment connected and I need the data stream to understand what the TV is sending to the app.The easiest option would probably be to make a simple converter box to and put it between the BeoRemote app and a lintronic box. It also looks like http://www.mammutbox.com/ is coming out with a lower cost alternative to MLGW, so an option would be to user that box and the BeoLink app instead of the BeoRemote
Page 1 of 1 (15 items) | RSS
DigiCert Secured Site Seal
