Connect Beosystem 2 to a Samsung UN55ES8000 Smart TV
griopas
Posts 3
griopas Posted: Wed, Oct 10 2012 9:50 PM
I have recently rent a house with a built-in AV system based on BS2 and Beovision 4-37. A few months ago I had bought a 55" Smart TV which of course I like to  combine with the outstanding B&O sound stage, while replacing the aged 37" monitor.
My questions are :
a.- Can I use a VGA to Component cable to connect the BS2 to my TV?
From the very useful http://archivedarchivedforum2.beoworld.org/forums/p/34302/282827.aspx#282827 post, I understand that BS2 VGA output is a standard one. Will buying a cable like this http://www.amazon.co.uk/15-pin-svga-vga-Jacks/dp/B0069HLUU2/ref=sr_1_6?ie=UTF8&qid=1349901184&sr=8-6 allow to connect BS2 VGA-Out to Samsung's Component-In?
b.- Alternatively, can I use a VGA to HDMI converter like http://www.amazon.co.uk/KanaaN-Audio-HDMI-Converter-Adapter/dp/B003U4NHL2/ref=sr_1_5?s=electronics&ie=UTF8&qid=1349901307&sr=1-5 to get the signal through?
c.- What about RS-232. How will I go around? There is a suggestion on above forum to create a dummy serial cable with pins 2-3 connected to trick the system/ Any schematics available? Other solutions?
Thanks for your replies
Gregory
hfat
Vienna, Austria
Posts 663
hfat replied on Thu, Oct 11 2012 3:39 PM
I'm using this configuration with a Panasonic VT30. I don't use the VGA output signal from BS2, exept for using the Setup-Menu. The HD singnals of external boxes are passing by BS2 directly to the TV, sound ist going to BS2. When playing TV sound is going from the TV to BS2.
Everything is controlled by B&O remote using Lintronic.
If you have the BS2 user Guide at hand, have a look at the section dealing with HD-Signals.
I'm currently not able to access my library, if your'e interessted I can post detailed Information later.
hfat
griopas
Posts 3
griopas replied on Thu, Oct 11 2012 10:06 PM
Thanks a lot! That's exactly what I want to do also.
Highly interested for the detailed info.
You said you don't use the VGA output other than for setup-menu. That's the only reason I want it also. So I suppose you have connected it to your TV on TV's VGA input. The RS-232 from BS2 was left not connected?
You also mentioned that sound has been streamed from devices to BS2. I suppose by coax SPDIF. No Video connection at all to BS2?
Thanks for your help,
Cheers
Gregory
hfat
Vienna, Austria
Posts 663
hfat replied on Fri, Oct 12 2012 6:12 AM
griopas:
No, i used a converter like this to convert to SCART AV-Signal as my TV has no VGA input. You need to be careful as BS2 uses RGBHV 575P 50Hz output signal, which needs to be compatible for yout TV's VGA input specs.
griopas:
Yes, it is left unconnected, but pin 2 and 3 are shortcutted, otherwise BS2 will not startup.
I use all 4 possible AV-inputs of BS2 and have sources assigned to them as usual in the setup. Depending on the capabilities of the source I use analoge or digital sound input via coax SPDIF. No videoconnection at all.
hfat
griopas
Posts 3
griopas replied on Fri, Oct 12 2012 10:43 PM
Thanks again, it is clear I will do the same.
any schematics which ones are the 2 and 3 pins on RS232?
Cheers
Gregory
hfat
Vienna, Austria
Posts 663
I simply use a gender ganger with a piece of conductor to pins 2+3.
hfat
Page 1 of 1 (6 items) | RSS
