I believe it adjusts automatically to the light of the room, a bit like the BeoVision.
I too believe that the BS5 has a contrast screen.
I too would like to adjust the display brightness on my Beosound 5. I can't find any info anywhere. If it does auto adjust as suggested it's not to a level that I find satisfactory. Sureley there must be an adjustment somewhere?
My BeoSound 5 hasn't the adjustment too.
Is it too low ?
Mine is fine.
