Beo4 problem.
Tucker
Ponte Vedra Beach, FL, USA
Posts 439
Tucker Posted: Fri, Feb 9 2018 12:30 AM
 My Beo 4 seems to be stuck...  It only shows "TV" no matter what button is pushed and all of my B&O equipment seems to be unresponsive to it.  I have changed the batteries but no luck.  Is it dead?
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000,  Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Sounds like what you said - the TV button is stuck in the down position.  Is it transmitting?   Look at the top end of the remote thru a digital camera.  You should see the IR light if it's transmitting.
Stoobietoo
Exeter, Devon, UK
Posts 692
Have you tried adding the "Reset" to the list and resetting it. That works on the Beo4 with the Navi Button. I can add reset to my list on my standard Beo4, but didn't want to try it in case it messes mine up.
Stoobie
Page 1 of 1 (3 items) | RSS
