BeoNut since '75
OK, I give up, what is "it?"
Jeff
Jeff:OK, I give up, what is "it?" Jeff Beovirus victim, it's gotten to be too much to list!
Use rubber bands? No wonder I didn't recognize it, I've never seen a pair in real life. Is it the type of plastic a plastic glue like for models might work?
Jeff:Use rubber bands? No wonder I didn't recognize it, I've never seen a pair in real life. Is it the type of plastic a plastic glue like for models might work? Jeff Beovirus victim, it's gotten to be too much to list!
elephant: Jeff: Use rubber bands? No wonder I didn't recognize it, I've never seen a pair in real life. Is it the type of plastic a plastic glue like for models might work? Jeff Beovirus victim, it's gotten to be too much to list! Good suggestions. The rubber bands could match the one in my ponytail However first step is a visit to the store tomorrow ... if I can find the purchase / warranty paper work !
Good suggestions.
If you look very closely at the side of the in line volume control you will see the serial number of your H5's. As long as they have been warranty registered you shouldn't need your original invoice as the serial will be in the B&O warranty database.
Opman
elephant: The rubber bands could match the one in my ponytail
Elephants don't wear pony tails.Pics or it didn't happen.
Opman:If you look very closely at the side of the in line volume control you will see the serial number of your H5's. As long as they have been warranty registered you shouldn't need your original invoice as the serial will be in the B&O warranty database. Opman
elephant: Opman: If you look very closely at the side of the in line volume control you will see the serial number of your H5's. As long as they have been warranty registered you shouldn't need your original invoice as the serial will be in the B&O warranty database. Opman I may have neglected to register
If you want to PM me the serial number I'll be happy to check if it is registered for you.
Regards
Opman: If you want to PM me the serial number I'll be happy to check if it is registered for you. Regards Opman
Amazing - you are right - on the side of the inline volume control there is a serial number !
Not that I doubted you, but I could not see it, unless I took off my glasses, and then only with the worst eye, and then only when I squinted, and then only when I angled it for reflection !!
I have PMed you the number thanks so much.
