BM4400 Spares or Repair
This post has 124 Replies | 0 Followers
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig replied on Wed, Feb 21 2018 8:22 AM
Not all is well...........replaced the D204 & D205 diodes and was disappointed, still no mV on the emitter resistors as I was hoping, however the overload lamp has stopped coming in and the left channel still continues to work fine. Next up will be the Zener  Diodes D202 and D203. I do have power on the +35 and -35 rails so will need to follow this through. Such fun...........
Beo_Jean
QC, Canada
Posts 334
Beo_Jean replied on Wed, Feb 21 2018 12:25 PM
I'm still waiting for parts to pursue mine but having the same problem where I can't adjust the bias on the left channel.
Curious to know if changing the zeners will cure the problem!
I choose the modern equivalents 1N52242B & 1N5223B but i prefer to have all the parts in hands before changing them.
I'll stay tuned to see how it turns out with yours.
Craig
Posts 2,040
Silver Member
Ok....I've just spent over four hours testing and measuring voltages, comparing readings from one channel against the other and could not find any significant differences.....so frustrating. I also replaced the two zener diodes to no avail, eventually sitting glaring at the damn thing and uttering oaths it dawned on me that when replacing the emmiter resistors I had soldered them both into the board in the same orientation, not a problem functionally....however you cant measure the 5.4 mV unless your across one of them.....with them soldered in the same way around I could never measure jack ***!
swapped one around and bingo.......off to bed now.
Craig
Posts 2,040
Silver Member
connected spotify via Tape 2 and injected a track, left channel great right channel not so great....bit of probing around revealed a loose connection on one of the plug and sockets at the input to the right channel......bit of jiggling and the right side is now singing like a bird.Will need to bottom put the poor connection thing but as I'm going to recap the whole thing I wont worry about it right now. Changed to big power supply cans and also the quiet current trimmer, will need more parts to complete.
Craig
Posts 2,040
Silver Member
Just had to share these.....surely it would have been easier just to buy a couple? love it ;~)
Beo_Jean
QC, Canada
Posts 334
Beo_Jean replied on Fri, Feb 23 2018 12:44 AM
Stick out tongue Good for the museum!
Craig
Posts 2,040
Silver Member
As I'm waiting for the postman I have started to look at the case, decided on a walnut burr veneer for this one.
Craig
Posts 2,040
Silver Member
As I was testing the left channel I noticed the output transistors seemed to be getting quite hot for such a short power up duration, in particular OTR100.....didn't think too much of it and I'm certain, or thought I was certain, that when I originally attempted to set up the quiet current on the left side I was getting the 5.5mV across the top of the two emitter resistors and it did appear to respond to the trimmer being adjusted.....but now that I look closer at this pair of resistors they are actually installed the same way around as the right channel resistors which wouldn't allow measurement of the prescribed 5.5mV. Looking at one of my functioning machines shows the left two resistors installed in opposition too......I suspect our DIY chap may have removed the right hand side of these resistors and just replaced it back to match the other one, I will reverse it before I power up.
Craig
Posts 2,040
Silver Member
This is a pic I posted from the Basket case exercise some time ago.....clearly shows the orientation of the left channel emitter resistors.
hemenex
Posts 569
hemenex replied on Sat, Feb 24 2018 9:27 AM
Craig:
sorry Craig but direction of a wire-resistor is irrelevant. Must be something else...
   hx
Craig
Posts 2,040
Silver Member
Hemenex.....thank you for your observation, however its not the direction of the resistor that creates the problem, its the orientation of the resistor in the board that is the issue......this simple diagram identifies the measuring points for the idle current mV (the tops of both resistors) and as can be seen with them in this orientation your measuring across a piece of wire.
Craig
Posts 2,040
Silver Member
However...if we rotate one of the resistors through 180 deg we find we are now measuring across one of the emitter resistors and not a piece of wire, I had to look long and hard at this too......
hemenex
Posts 569
hemenex replied on Sat, Feb 24 2018 11:30 AM
Craig,
after all you have shown here I couldn't imagine you would not be aware of such a simple issue Wink
Anyway you made me dig out my defective BM4400 I have as spare and have a look into it.
If you look at the printing on the PCB you'll find this:
E of IC101 goes to the "in picture upper" (unaccessable) sideof R179 while E of IC102 goes to the "upper" (accessable) side of R178. So measuring the 10-15mV across both resistors has to be upper left to upper right of the resistors..
You could more easily use the open wire of the right resistor and the emitter of IC101 at the orange wire to measure the mV's according to the service manual.
Sorry for having been confusing Sad
   hx
P.S. I own a technical product information of BM4400 type 2417 which explains (among other topics)  the function of the power amplifier on 11 pages but it's in german.
Craig
Posts 2,040
Silver Member
Craig replied on Sat, Feb 24 2018 12:36 PM
Hemenex
No worries......I just prefer to measure from the tops of both resistors and look for half the recommended mV signal, thats a very good picture of how the resistors need to be installed to permit this, incidently....I dont suppose your spare BM4400 has a power switch you dont require?
Craig ;~)
Craig
Posts 2,040
Silver Member
Took a wire brush to the bottom plate to get all the rust removed, will need new feet also...ordered 4 similar ones from ebay.
Craig
Posts 2,040
Silver Member
Coat of primer ready for a matt black spray, had to sacrifice the dismantling instructions....but I think I can live with that ;~)
MrRoast
Posts 340
MrRoast replied on Sun, Feb 25 2018 7:24 PM
Top class work as always! As for rust removal I use this stuff - fantastic stuff
https://www.bilthamber.com/corrosion-protection-and-rust-treatments/deox-c
hemenex
Posts 569
hemenex replied on Tue, Feb 27 2018 4:05 PM
Craig:
Ain't that the same one as in BM3000 / BM4000? Then chances are rising... Wink
  hx
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Feb 27 2018 5:27 PM
hemenex:
Craig:
  hx
Sadly it isn't.
Craig
Posts 2,040
Silver Member
Craig replied on Tue, Feb 27 2018 7:22 PM
Yes.....I know this, I have a 4000 removed the case and bottom cover to have a look ;~)
One will turn up in the fullness of time I'm sure, scary thing is it may come with a complete bank of switches and require the replacement of the whole set....it does not look an easy task replacing just the power switch in isolation either! (how hard can it be?)
Beo_Jean
QC, Canada
Posts 334
Craig,
You may want to look if you can fit this type of switch instead?  There is a bunch of different models available at Mouser and maybe one would fit.  You will have the ON/OFF function but you will lose the input release switch mechanism...
hemenex
Posts 569
hemenex replied on Wed, Feb 28 2018 7:21 AM
Dillen:
Sadly it isn't.
Are you sure?
BM4400 mechanical parts list pos. 45 mains switch # 7450010
BM4000 mechanical parts list pos. 90 switch # 7450010
BM3000 mechanical parts list pos. 89 switch # 7450010
or isn't that the switch we are talking about? What am I getting wrong here? Sad
I know you are the expert...
  hx
Dillen
Posts 13,191
Dillen replied on Wed, Feb 28 2018 7:35 AM
Correct for the early version of Beomaster 4400.
The switch was changed (together with the rest of the switch row, the potentiometers, the tuner front-end and a few other things) from s/n 1524001 to a different type.
The old and new parts are not interchangeable:
https://type181.files.wordpress.com/2014/07/7450010.jpg
hemenex
Posts 569
hemenex replied on Wed, Feb 28 2018 1:40 PM
Ok then as my BM4400 type 2417 SN starts with 1424... and that proves it's an earlier one. Its switch looked equal to BM3000. What about craig's SN?
Did they change the type number on redesign? I don't think so.
Thanks,
  hx
oops, should have read the whole thread where the different mains switches were already mentioned. But couldn't find craigs SN.
My power transistors are mounted in a different style; looks more like a plastic screw instead of the nut in Craig's pictures Does this point to a newer SN?
Craig
Posts 2,040
Silver Member
Ok.....serial No for my latest endeavour is 1601023, the weather has prevented any deliveries of the bits and pieces I have on order to progress so I have spent a little time looking at the darlingtons I removed, I acquired this transistor analyser and thought I would give it a run out.
Beo_Jean
QC, Canada
Posts 334
I bought this analyser a while ago; very useful tool!
Craig
Posts 2,040
Silver Member
Craig replied on Thu, Mar 1 2018 7:30 AM
It certainly would appear so.......it provides a huge amount of information about the device under test when connected to the laptop, unfortunately almost all of it means little to me given my current level of understanding, I need to condense the information down to the meaningful parameters, the ones that identify if the piece is good to go or not......I think comparing the readings with the published data sheet is a good place to start, any member opinions are welcome on this ;¬)
Beo_Jean
QC, Canada
Posts 334
Craig,
The values important to me are the HFE and the leakage.
HFE where for a given transistor, the value must meet the minimum requirement of course.  Also, when they are pair matched, I'm trying to match them within 10% to avoid one working harder than the other.  It is also preferable to balance right and left channel HFE... but not always possible unless you change them all...
Leakage, well you don't want a transistor to leak current when it is not supposed to...
Søren Mexico
Mexico City
Posts 6,411
Craig: I may have a working switch for you. I have a newer model BM 4000, bought for spares, newer tested it.
Dillen
Posts 13,191
Dillen replied on Fri, Mar 2 2018 6:46 AM
BM4000 never used the newer switch.
It's unique to the later BM4400.
Craig
Posts 2,040
Silver Member
Craig replied on Fri, Mar 2 2018 7:50 AM
Søren Mexico:
Craig I have a BM 4400 coming in after Xmas, bought it for parts, maybe the top cover is better than yours, the top free to go for shippingcosts
I was hoping Soren was referring to this BM4400 and not a BM4000
Søren Mexico
Mexico City
Posts 6,411
Craig:
Søren Mexico:
It was a typo, of course I mean BM 4400, let me check this weekend if it works.
Craig
Posts 2,040
Silver Member
Craig replied on Sat, Mar 3 2018 8:32 AM
Soren
That would be great, some pictures of how you get it out would be appreciated too Big Smile
Søren Mexico
Mexico City
Posts 6,411
Craig:
Soren
Will do, stay tuned tomorrow
Craig
Posts 2,040
Silver Member
plywood shapes arrived today, had them cut to the overall size but without any shaping....
Craig
Posts 2,040
Silver Member
Cut the front chamfers and marked up the cuts to allow the cover to slide ober the protruding screws of the chassis....
Craig
Posts 2,040
Silver Member
bought this snappy little accessory for the dremel.....router attachment, never used one before so was a little nervous.
Craig
Posts 2,040
Silver Member
Overall, and considering no one will see it, it turned out quite well......will need to start the veneer exercise as soon as I have softened and flattened it out.
Søren Mexico
Mexico City
Posts 6,411
Craig:
I like that, good for these small cuts, I have a big router that came in handy for some speaker frets
Søren Mexico
Mexico City
Posts 6,411
Craig, was just about to start on the BM 4400, got visitors, will have to wait until tomorrow
Page 2 of 4 (125 items) < Previous 1 2 3 4 Next > | RSS
