Beoplay E8
This post has 21 Replies | 2 Followers
lukerglen
Posts 3
lukerglen Posted: Tue, Feb 13 2018 3:46 PM
Just bought these. Sound is crisp & clear. Awesome so far. However I was wondering if there is some way to change the audio settings/equalizer App etc so that I could pump up the base a little. It's lacking in this area.
Jon
Hampshire, United Kingdom
Posts 241
Jon replied on Tue, Feb 13 2018 3:50 PM
Glad you like them! You’ll be able to do it in the BeoPlay app in the ToneTouch section :)
Aussie Michael
Melbourne, AU
Posts 3,730
lukerglen:
How do they fit in your ear ? Are they like the earset 3i and just sit in your ear or do you have to cram them in for them to sound good ?
lukerglen
Posts 3
lukerglen replied on Sat, Feb 17 2018 3:28 PM
Sorry I don't know what the earset 3i are. I've always a bose customer. These are my first B&O purchase.
Yes I do push them in but I use the foam ear plugs rather than the plastic/rubber ones so they fit snug.  I've not noticed they get uncomfortable at any point so far. They certainly don't slip out.
I've since used the beo app to lean more base into it and now it's marginally more basey, but it's still light. Regardless, the sound is crisp & clear and despite no noise cancellation capability, they are just as quiet as my noise cancelling bose head phones. Interesting.  Actually I've noticed that even if I pause the music, I often have to tap the left ear to turn the 'transparency' on, to hear someone talking to me...they are very effecting blocking/isolating ambient noise.
w5bno123
London
Posts 578
w5bno123 replied on Sat, Feb 17 2018 3:48 PM
When you’re in Tonetouch you can expand the dot and make it much bigger to cover more of the EQ which makes the earpiece slightly louder as well.
lukerglen
Posts 3
lukerglen replied on Sun, Feb 18 2018 11:52 AM
Ah, cool. That wasn't obvious. Thanks for the tip. It's effective.
mr_anders_son
sweden
Posts 1,710
https://www.bang-olufsen.com/en/earphones/beoplay-e8
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Feb 14 2019 12:46 PM
mr_anders_son:
I have had my E8 2.0 a week now.
Really nice. Feels like real premium product with the nice brushed aluminium in the little box. Very crisp and detailed sound and good bass when you have found the eartips that fits best.
I have not been able to get them to work with the B&O app though.
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Feb 14 2019 8:06 PM
Silou
Switzerland
Posts 465
Silou replied on Sun, Dec 8 2019 3:39 PM
Very disappointed by the sound (V1) !!! AngryWorst than ever. No bass at all. Original Apple headphone with wire is much better !
Silou
Switzerland
Posts 465
lawrencejmcook
Posts 742
I have the E8 original version and found the sound a bit flat after hearing the H9i.
I use the Commute ToneTouch preset, and for me this works well. I still prefer the H9i, though.
Make sure the B&O app and the E8 firmware are up to date. Then play with the ToneTouch until you’re happy.
Lawrence
Svenni
Berlin, Germany
Posts 48
Svenni replied on Mon, Dec 9 2019 5:09 PM
You must be using them wrong, there's no way Apple earbuds have more bass than an IEM. You need to make a seal, if the tips are barely touching your ear canal, push them in further. Try smaller or bigger tips, or chaging the type (silicone or foam).
Beoplay A2
Beoplay Earset
Beoplay H6 (Gen 2)
Beoplay S3 (pair)
Beoplay S8
Beovox CX50 (2 pairs)
Beovox RL 6000
Stan
Chicago-area USA
Posts 869
Stan replied on Mon, Dec 9 2019 10:32 PM
I find the rubber tips give better bass (at least in my wired B&O earbuds (E4s)).
marcengels
Posts 44
Does anyone know how to expand that dot. I cannot figure it out.
marcengels
Posts 44
By that I mean the dot in the Beo app, Tone Touch.
Duels
England
Posts 2,553
Duels replied on Wed, Dec 11 2019 9:28 AM
I think you put two fingers on the dot and move them apart.
marcengels
Posts 44
marcengels replied on Wed, Dec 11 2019 12:59 PM
I tried that before but unfortunately it did not work!!! Any other suggestions maybe?
marcengels
Posts 44
I do not know if it makes any difference but I own the Beolplay E8 2.0 Motion!!
AD1214N
Posts 37
AD1214N replied on Wed, Dec 11 2019 3:33 PM
Was just going to take a look but unfortunately the app has decided it’s not going to connect to them today but I’m sure you place your thumb and index finger over the spot and expand or pinch to increase and decrease the range.
Sitting Room BeoVision 11-46 Motorised Floor Stand - BeoLab 11 - BeoRemote One - BeoCom 5 - Beogram 3000 (Type 5228) - Cambridge Audio Alva Solo Preamp - Oppo BDP93EU - Apple TV 4K (2gen) - 3D Glasses Kitchen BeoSound 1 - BeoRemote Halo - BeoCom 6000 mk2 Bedroom BeoSound 35 - BeoRemote One - BeoTime Bathroom BeoSound Level Utility Room BeoSound  Level Home Office BeoSound 2 - BeoRemote Halo - BeoCom 6000 Mk2 Home Gym BeoLab 28 On The Go H95 - H7 - E8 3.0 - H5 - A2
AD1214N
Posts 37
AD1214N replied on Wed, Dec 11 2019 4:07 PM
Managed to get working again with a app update and you’re right oddly you can’t expand the spot. Actually having trouble with the app with not finding B&O Play products, Bang & Olufsen ones seem fine though. But out of ideas, never found the E8’s to be that punchy earphones but if you don’t mind wearing headphones audition a pair of H9i’s you’ll be wow’d by them but in the meantime play around with the rubber tips, you’ll be surprised what a difference finding the right tip will make. If definitely earphones you want and don’t need noice cancelling try the H5/E6 Active think they have a tad more bass. Sorry probably not what you want to hear after investing in the E8’s but hope you’re still happy with them.
oli
Southeast of France
Posts 141
oli replied on Wed, Jan 15 2020 4:09 PM
After the E8, the E8 2.0 and E8 Motion, here we have the E8 3rd generation:
https://www.youtube.com/watch?v=cbZVO9h929k
https://www.youtube.com/watch?v=2dK_QI6HuxY
Page 1 of 1 (22 items) | RSS
