Which speakers for open plan dining room and how to connect?
This post has 15 Replies | 0 Followers
Brian
London/Aarhus
Posts 219
Brian Posted: Thu, Feb 15 2018 12:29 PM
Hi all,
I’m not particularly ‘techy’ so thought I would seek the help of like minded others that perhaps are.
We are currently rebuilding/remodelling our house to the extent that only 2 gable ends were left standing, roof off, second floor totally demolished and ripped out, you get the picture.
Our new L shaped open plan kitchen - dining room - lounge area will be 100 square meters. In the TV end of the lounge I am installing a BV11-55 with BL5 front speakers and BL3 rears, a Beocenter 2 connected to the BV11 by a custom made cable from Steve at Soundsheavenly, and a beogram 5500 into the BC2 socket box via a Aux input switch box also from Soundsheavenly https://soundsheavenly.com/music-input/aux-input-switch-box-for-multiple-input-devices-to-one-aux-socket-4-way  I thought having some spare aux input sockets might come in handy at some point perhaps hence this box. I tend to play my music from apple devices so I’m assuming an Apple TV connected to the BV11 would be able to handle this?
I would like to place a set of speakers in the dining room section of the open plan, two central pillars holding up the steel structures are perfect for this being 500 mm wide each by 2300 mm tall - plasterboarded and plastered/painted. Perfect blank canvas for speakers.
My question to you fellow enthusiasts is how to do this and with what? I want to be able to play music in the dining room area independently via an apple device without the TV speakers playing but with an option for both the TV end and the dining room to play at the same time should I wish to.
A BS35 is not an option space wise and besides, I already have 2 of those, one in the cigar lounge and one in the master bedroom. I guess a BS2 on the dining room side table could be an option but I think I would prefer mounting speakers onto the blank canvas pillars if possible for a more ‘fitted & installed look’ if you see what I mean. I’m thinking perhaps a set of wall mounted BL12-3 or a set of wall mounted 8000s or 18s would suit the pillar space.. I can easily still run cables to these pillars from the BV11-55 as we have not plastered yet.. but how to connect and play these independently??
I’m taking lots of photos as we progress and would be happy to share in due course when the hardware is put in - in the meantime I would be very grateful for any advice and input you might share regarding my required setup.
Many thanks
Brian
Brian
London/Aarhus
Posts 219
Brian replied on Thu, Feb 15 2018 12:47 PM
Trying to upload pics but am not able to for some reason.
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Feb 15 2018 1:41 PM
How about another pair of BL3:s connected to the BL3s but placed in the dining area (with a wall mounted BL11?)? You can create a speaker group for those alone, and also a combined speaker group if you want to play all speakers at the same time.
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Feb 15 2018 1:43 PM
Brian:
Easiest to do via the app on eg an iphone.
Brian
London/Aarhus
Posts 219
Brian replied on Thu, Feb 15 2018 1:54 PM
Good suggestion but I think an elongated speaker might sit better on the long thin pillars.
Forgive my ignorance but are you saying it is possible to create a separate speaker group on the BV11-55 for the dining room? It is my understanding that the BV11 only has 5 RJ45 inputs which I guess is why you suggest connecting the extra BL3s to the existing rear BL3s - but surely this would mean that all the BL3s would play at the same time?
Duels
England
Posts 2,553
Duels replied on Thu, Feb 15 2018 2:14 PM
Brian, I just love that you have a cigar lounge.
Mikipidia
Posts 2,169
Mikipidia replied on Thu, Feb 15 2018 2:41 PM
To my knowledge you can do two speaker per rj45 fitting. I only have 2 rj45’s in use with two bl50’s and two bl18’s. So 5 rj45 fittings would technically give you wired connections for 10 speakers. I also made a second group for when i want to only use either of the speakers or even just the tv. Options with speaker groups are endless, you can even select just one speaker out of all of them if you so wishedStick out tongue
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Brian
London/Aarhus
Posts 219
Brian replied on Thu, Feb 15 2018 4:29 PM
Thank you, I was in no way intending to boast..just slipped out with the mention of the 2 x BS35s. About 20 sq meter room, glass floor to ceiling walk-in humidor 2 meters wide by 1 meter deep: Havanas only. Leather chairs, dimmed lighting - a good place for the boys to kick back :-)
Brian
London/Aarhus
Posts 219
Brian replied on Thu, Feb 15 2018 4:41 PM
Thanks Mikipedia, I had no idea about the speaker group options on a BV11... I just bought the TV and stored it away until our house I finished.
So, in that case I should be able to just run some powerlink rj45 cables from the dining room and simply plug into the BV11 and select those two speakers as a group? ..and make a separate group for the 4 speakers around the TV and another group for all 6 speakers? I hadn’t realised it was that simple if that is indeed the case..
Mikipidia
Posts 2,169
Mikipidia replied on Thu, Feb 15 2018 8:35 PM
That’s more or less what i do on my eclipse yes. I pretty sure it’s the same on an avant, iam not 100% sure on how it works with the bv11 but i think it’s very similar to an avant so it should work the same(i never owned a bv11). If you can make speaker groups it’ll deffinately work like that. It’s a wonderfull optionBig Smile
Fidse
Posts 175
Fidse replied on Thu, Feb 15 2018 10:21 PM
I don’t know if the BV11 is WISA capable, but if not, you can buy a transmitter : https://b-o-f.dk/produkter/beolab-transmitter-1-i-hvid
And send the sound wireless to the newer speakers, 18’s, 17’s and the 19 subwoofer. You can also get a receiver you plug into older speakers like your 3’s or 8000’s so they can receive sound wireless to.
Fidse
Posts 175
Fidse replied on Thu, Feb 15 2018 10:22 PM
Sorry, i meant the BV11 of course.
And now i just found out, that i can edit my replies Big Smile
Millemissen
Flensborg, Denmark
Posts 14,680
Brian:
In the meamtime you could read this to learn a bit about, what you new tv is capable of:
http://www.tonmeister.ca/wordpress/2014/08/04/bo-tech-combinatorics/
egges
germoney
Posts 303
egges replied on Thu, Feb 15 2018 11:21 PM
just to be independent from the TV and/or for casual listening i would feed the new speakers with an Essence or a Core.
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound +  appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Brian
London/Aarhus
Posts 219
Brian replied on Sat, Feb 17 2018 11:05 AM
Thank you for all the replies guys - food for thought.
I will run a pair of rj45 leads from the two pillars to the BV11 before we plaster to cover all bases.
Photos to follow in due course.
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Feb 17 2018 11:31 AM
Make sure they are shielded cat cables, i went with cat 7 just because they’re the best so far. And imo it’s worth it just to stop any interference you may have or get over the years. We’re all waiting for some photo’s Big Smile
Page 1 of 1 (16 items) | RSS
