Beovision 9-50 life expectancy?
This post has 8 Replies | 0 Followers
Peter
Sweden
Posts 84
Peter Posted: Sun, Feb 18 2018 4:34 PM
Hi All,
I am looking into buying a second hand Beovision 9-50 and I have a few questions:
- What the difference between Mk I, Mk II and Mk III ?
- How long would you expect a plasma to last? is it deteriorating badly after a few years compared to LED and LCD?
- Is it worthwhile getting a Bv 9-50 if I can get a Bv 10-46 for just a little more money? is that a better choice?
Would be interesting to hear your thoughts on this..
Peter
Beovision 7-40 Mk VI, Beovision 3-32, Beovision AV9000, Beovision AV5, Beolab 8000, 6000, 5000, 3000, 2000,  Beocenter 2300, 9000, Beocenter 2, DVD1, DVD2, Beogram 3300, LC2, Beolit 12, 3 x AppleTV
Evan
USA
Posts 3,621
Evan replied on Sun, Feb 18 2018 7:31 PM
Following this thread with extreme interest. Always always wanted one of these (and still do). Without a doubt it is my favorite TV (beovision or not) but unfortunately it is not going to fit in my next apartment. Sometime I WILL own one and I'm worried that by the time all the circumstances align, the TV will be too old to bother with.
Beo4 'til I die!
Peter
Sweden
Posts 84
Peter replied on Mon, Feb 19 2018 7:09 PM
yes.. let's hope there are someone with experiences about this amazing TV... ;)
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Mon, Feb 19 2018 8:01 PM
hi peter!
there is no bv9-46!! only a bv9-50
bv9-50
mk1: hd ready
mk2: full hd - 1080p; Typ 9720-9730
mk3: +apc-acm, D9-Panel, Typ 9760-9772 (3/2008)
Mk4: D10-Panel, Typ 9773-9784 (11/2008)
Mk5: D11-Panel, Typ 9785-97996 (8/2009)
https://archivedarchivedforum2.beoworld.org/forums/t/41573.aspx
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
YannChris
Larmor Plage - France
Posts 232
YannChris replied on Mon, Feb 19 2018 8:08 PM
Hi Peter,
My BV9 is a MkIII one:
Full HD and ACM (little camera which calibrates the screen every 200 hours).
Bought new on mid-2007, still strong and healthy.
I really appreciate the soft image of this set, far less agressive than LCD, more "Cinema" experience.
The built-in speaker matches my BL5 very well.
Integrated with a Moment, a BC2, a PS3 and a Tvix through NL/ML converter, all work flawless in all my rooms.
To be short, I'm really happy with this true B&O set... and no software troubles!
Kind regards,
Yann
Living Room   BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge  Beolink Passive - Cabasse Clipper - Beo4      Kitchen  BL3500 - Beolink 1000
Bedroom    BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge   BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study    BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
Peter
Sweden
Posts 84
Peter replied on Mon, Feb 19 2018 8:15 PM
Thanks Beoandy! :)
It was a typo.. I meant to write 10-46. sorry about the confusion! :)
Thanks for letting me know the difference between the generations. Didn't even know there was a Mk 5...
/Peter
Peter
Sweden
Posts 84
Peter replied on Mon, Feb 19 2018 8:19 PM
Thanks YannChris.
Good point there.. I have read a lot about all the software issues on Bv10 and 11..I will use a Apple TV anyways, so no need for any SmartTV features for me. Good to know its still going strong after more than 10 years. and I also enjoy the softer image that also handles a bad signal better it seems. Sometimes the new LED's are sometimes "better" than real life in the picture quality, which makes it fel a bit unnatural..
Peter
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Feb 20 2018 10:09 AM
Peter:
Do not rule out BV 10 and 11 based on potential SW troubles. I had a BV10 and still have a BV11 and not seen any such problems. This may be confused with BV14 (using Android OS) that was initially plagued with problems.
Agree that plasmas have a nice soft picture.
kai
Posts 362
kai replied on Tue, Feb 20 2018 1:25 PM
Just be careful had a friend with bvis 10-46 turned out after changing the chassis and power board it turns out it’s the lcd panel which you can get anymore.
Page 1 of 1 (9 items) | RSS
