Hi all,
My Beo6's battery has completely drained and I cannot bring it back to life.
I put it on the charger or connect it to my PC, nothing happens.
Any solution?
As I'm not skillful, opening the set is not an option for me.BTW, my Beo5's battey is nearly dead and I'm also in search of a solution.
Thansk by advance and kind regards,
Yann.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
Up!
YannChris: Up!
Your only solution are new batteries. Your Beo6 might also need a firmware upgrade, as they have issues waking up with drained batteries.
They can be fixed, but not without disassembly.
/Jacob
