How do I connect 4 Beolab 6000 and a active Mission Subwoofer to a HDMI (Arc) or Optical connection?
This post has 18 Replies | 3 Followers
Arje
Posts 9
Arje Posted: Thu, Feb 22 2018 11:09 AM
No. Not a first timer. Did a lot of research. Also at this nice forum (in Dutch). I have a Loewe (Model from 2008) now and the speakers are connected trough a Detoma Umschaltbox. The center speaker is the original Loewe TV speaker.
I want to buy a Samsung TV (The Frame) with an HDMI Arc and Optical connection.
There is a solution (€ 900,-) to connect the Beolabs but there is no connection for my Mission Subwoofer. A secondlife Sub from B&O is expensive. Then there is the problem of the centerspeaker. I can buy a second life 7.1 center speaker.
Now I am thinking of selling all of it an buy a SONOS 5.1 system. Soundbar, Sub and 2 Play:1
I was looking for a pre-amp system (I don't need an amp) but even this is very expensive. Buying something new is perhaps better but I love those 6000...
Did I try everything? Did I miss solutions? Or do I need to run to the shop and get me a SONOS system and put the speakers on sale... Help!
Beosince98
Posts 274
https://www.amazon.de/Ligawo-6518770-Multiformat-Konverter-Mehrkanal/dp/B015XQ1O00/ref=sr_1_4?ie=UTF8&qid=1519322005&sr=8-4&keywords=5.1+hdmi+converter
I have not tested this device, but it seems to be exactly what you need!
Arje
Posts 9
Arje replied on Thu, Feb 22 2018 6:32 PM
Super! Thank you so much! € 123,- is better :-). Now for the final (and lazy) stupid question.... What converter cables do I need for these kind of plugs?
With this setup I only need a center speaker. I think the 7-3 of 7-1 is a bit of an overkill. Any sugestions what would fit soundwise with the 6000?
tuttivini
Posts 186
tuttivini replied on Thu, Feb 22 2018 7:09 PM
Can't you just buy a surround amp with preouts for all channels?
This way you can connect all your beolab 6000's to it with rca cables and also your non b&o sub. With beolab 6000 you don't specifically need powerlink. They also have an rca input.
I did this in my Dutch parents home, to connect 2x beolab 3, 1x beolab 7.2 and 2x beolab 6000 to his new Samsung uhd tv.
I used a marantz sr5011 for this. Connect with HDMI arc, it automatically switches on when you turn on the tv and you can use the tv remote to change volume. Excellent surround sound. Also because you can use the Auddessey microphone to make a correct measurement for your specific setup/room.
Of course you can also use such surround amps for build in things like airplay, spotify connect, etc!
tuttivini
Posts 186
tuttivini replied on Thu, Feb 22 2018 7:15 PM
Beosince98:
This DOESN'T WORK! Because you can't change volume. So always on MAX volume if you directly connect active speakers, like the 6000's to it.
Arje
Posts 9
Arje replied on Thu, Feb 22 2018 7:18 PM
Are you Dutch? ;-)
Ok. Thnx.
The disadvantage of such a system as the Marantz is that you'll have to pay a lot for things you don't really nead. What I don't need. I just want to play my (still to buy) Samsung TV over the Beolabs 6000. No nobs.. No turn switches. Just when the TV turns on, there will be sound :-).
But I perhaps I want to much.
Beosince98
Posts 274
https://www.amazon.de/gp/aw/d/B075G6TG3Y/ref=mp_s_a_1_3?__mk_de_DE=ÅMÅZÕÑ&qid=1519328483&sr=8-3&pi=AC_SX236_SY340_QL65&keywords=5.1+hdmi+converter&dpPl=1&dpID=41ER9usAePL&ref=plSrch
Then this seems to be what you need!
tuttivini
Posts 186
tuttivini replied on Thu, Feb 22 2018 7:51 PM
Ik ben inderdaad Nederlands ;)
Ik snap je probleem. Ik heb voor mijn vader ook werkelijk elke oplossing bekeken en overwogen omdat hij het ook zo simpel mogelijk wilde hebben. Alleen omdat hij per se 5.0 surround wilde en er niet meer dan zeg 600 euro aan uit wilde geven, werd dit de oplossing. Die oplossing werkt weliswaar erg goed. Klinkt goed en omdat de Marantz ergens weggewerkt in een kast staat, is het geen probleem. Maar er zitten idd wel veel functies op die je nooit gebruikt...
Ikzelf koos in mijn woning daarom er maar voor om dan maar geen surround te hebben. Ik wil ook zo simpel mogelijk. Daarom heb ik zelf hier een b&o Playmaker direct op mijn Samsung tv. Op de Playmaker zitten direct twee Beolab 8000's. Gaan automatisch aan als tv aan gaat en regel het volume via een Beo4 afstandsbediening. Ook heeft de Playmaker airplay, dus muziek van de iPad (spotify enzo) komen ook automatisch over de 8000's. Switched automatisch naar juiste geluid tussen tv en airplay. Werkt gewoon altijd. Supersimpel. Niets zichtbaar behalve de tv en de speakers. Maar helaas dus geen surround...
Als je dat echt wil is er meen ik een apparaat van ALMANDO die dat wel kan. Die kost wel 900,- euro dus flink prijzig:
https://www.onlineplayshop.nl/multiplay-surround.html
Arje
Posts 9
Arje replied on Thu, Feb 22 2018 7:57 PM
Met die laatste is mijn zoektocht begonnen. Dan is een Marantz goedkoper :-)
tuttivini
Posts 186
tuttivini replied on Thu, Feb 22 2018 7:58 PM
Beosince98:
This also doesn't work. First because everything you want to adjust the (tv) volume, you have to walk towards this box. No remote. And secondly because if you use several different beolab speakers, with different sensitivity levels, you can't adjust this. For example: the beolab 7.1 will sound wáááy louder than the beolab 6000's with the same input level (input sensitivity).
tuttivini
Posts 186
tuttivini replied on Thu, Feb 22 2018 8:07 PM
Arje:
Elke hdmi surround receiver mét 5.1 PREOUTS voldoet in principe. Alleen die goedkope(re) modellen hebben vaak niet zo veel preouts. Die hebben enkel meestal stereo preouts. Maar Denon en Marantz maken ze oa wel. Ook tweedehands op marktplaats een Marantz SR5010 oid kan erg interessant zijn.
Als je er een beolab 7.1 bij wil heb je nog wel een verloop kabeltje nodig. Die heeft nml geen tulp ingang zoals de 6000, maar enkel een b&o Powerlink connector. Dus dan een kabelset nodig om die werkend te krijgen. Die worden is verkocht door de Engelse sponsor Soundsheavenly.
Je ziet het. Surround op een niet-b&o tv heeft nog al wat voeten in de aarde. Als je stereo wil is het allemaal wel makkelijk en onzichtbaar mogelijk. Zoal bijv met mijn uitgelegde Playmaker of met een Sonos Connect kastje. Zo heb ik laatst een Philips tv van een vriend op twee 6000's aangesloten. Werkt ook instant. Automatisch aan gaan en tv geluid als bron aan. En natuurlijk de sonos app mooi voor afspelen van allerlei muziek ook nog eens op je 6000's.
tuttivini
Posts 186
tuttivini replied on Thu, Feb 22 2018 8:30 PM
The Almando Multiplay is quite expensive but really does everything. You can change all the settings with their app on your phone. Settings like volume levels for each speaker. Lipsync. Inputs. Etc.
I read their manual and wow, if you have a non-b&o tv and want to connect it to 5.0/5.1 beolab speakers and also to things like for example an ouverture, a Chromecast audio etc. This is the easiest invisible solution without the need for extra remotes, auto switching, etc.
https://almando.com/media/documents/almando-multiplay-surround-decoder_en.pdf
Arje
Posts 9
Arje replied on Thu, Feb 22 2018 10:10 PM
Yes. I know. But € 900,- is a lot. My 6000 are conected under the floor of my house so I need to use the current cables. And with this Almondo device I can't use my Mission Subwoofer anymore (I think). Secondhand Subs from B&O are nice but... expensive :(
But to sell all my gear and buy Sonos is ofcourse also expensive. I need to make the calculation. Do I go for a easy (selling and buying stuf that is made in 2018) or do I go for an second adventure with the current stuf... :-)
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Feb 23 2018 5:50 AM
I am sure there is a cable option to use your sub with almando. Check soundsheavenly.com for details.
Ralf
Beosince98
Posts 274
tuttivini:
Beosince98:
https://www.amazon.de/gp/aw/d/B01EZGVXWI/ref=mp_s_a_1_3?__mk_de_DE=ÅMÅZÕÑ&qid=1519377483&sr=8-3&pi=AC_SX236_SY340_QL65&keywords=lautstärkeregler&dpPl=1&dpID=41UjK1QGceL&ref=plSrch
Then just buy 5 of these and you are golden! And yes, you can’t control it via remote.
tuttivini
Posts 186
tuttivini replied on Fri, Feb 23 2018 9:48 AM
You can use your sub with the Almando. You just need a rj45 to male rca cable. Costs around 30 Euro.
If you want to/need to use your existing powerlink cables for your 6000's, because all cables are in/under the floor, the almando is also the correct piece of equipment. You only need rj45 to powerlink adapter cables with it.
If you can't swap your powerlink cables for rca (Dutch: tulp) cables, and want to go for my suggested Marantz receiver with preouts, you need 5 sets of special trigger cables: rca to powerlink with 5volt triggering. These trigger cables are quite expensive and because you need 5 of them, the costs will possibility (if you can't find a nice Marantz second and) be the same as an Almando with rj45 to powerlink adapters.
Replacing everything for Sonos is even more expensive and the looks of those ugly play1/play3/play5 speakers are a downside.
tuttivini
Posts 186
tuttivini replied on Fri, Feb 23 2018 9:54 AM
Beosince98:
Also not a good option in daily usage. Because you don't have a remote and these boxes have a irritating distortion on low levels. A humming sound. I tried one myself on a airport express>beolab 6000, because I wanted the lowest volume setting to be lower... it worked but created a extra humming sound. Tried two of these cheap boxes...
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Beosince98:
Hi Arje and Beosince98,
I have just had one of these boxes in for testing and it will control the volume, but with one issue - the volume control is "stepped" instead of being continuously variable.  This means that the volume difference between "0" (no sound) and "1" (lowest volume) is very large with Beolab speakers.
Basically the options are:-
1) Another similar 5.1 channel DAC with a better volume control (I'm working on this, please bear with me!),
2) The Almando multiplay (sorry I can't comment on this as the guys at Almando won't answer any of my emails for some reason?)
3) Add an AV receiver with pre-out sockets for full remote control of the speaker volume, plus loads of extra features for sound and picture processing (although this comes at a higher price of around £500 GBP upwards).
If you decide to go for an AV receiver, I would suggest looking at the Pioneer SC-LX59, Denon AVR-X3400, Yamaha RX-A830 or RX-V775 AV processors/receivers, all of which have audio pre-out sockets for easy connection of Beolab speakers for a Dolby surround sound setup.
I am always happy to help with cables and advice, please feel free to click on my sponsor link below to get in touch at any time.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Kurzschluss
Posts 8
What about a Teufel Decoderstation?
I had one in use a few years Ago. I used the headphones out for normal 2Chanell operation and the optical out for 5.1Sound. For 5.1 I had to use the Teufel Remote for Volume but for normal TV the standard Remote is enough...
Page 1 of 1 (19 items) | RSS
