hi all just sold my beosystem 2500 and bought a beosound 9000 mk2 but having trouble linking my bathroom up again?
i have a beolink converter linked to a mcl2p amp running beovox cx100`s now this setup worked great with the 2500 but wont work with the 9000?
any ideas please
Kind Regards
Mark
You don't need the converter any longer, just connect the BS900 to the MCL2p with ML.
thanks, i was thinking the same but the house is wired up for beolink and would have to rewire the house for masterlink which would cost a fortune?
is there any other way?
BS9000 - Beolink active - MCL2P - CX100 should work.
Which Beolink converter did you use?
BTW - MCL2P has no Masterlink.
Stefan
sorry my mistake its a beolink passive and the beolink converter says type 1611 if that helps.
Ok. So what about a second converter:
BS9000 - ML - BL1611 - Beolink (MCL) - BL1611 - MCL passive - CX
