How do I get rid of the terrible soap effect on Beovision 8-40? Game mode helps, but it still are there. Any other things you can do?
BeoNut since '75
hehe, no. Always when I am buy new technical stuff I got to try more things. Right now I considering to but another tv, if I can get rid of the soap effect and the masterlink does not work. :)
The soap effect is called motionplus on Samsung tv.
The soap effect completely destroys a good picture. I cannot stand looking at the news or a film, where it looks like they are everybody dancing. I can completely reject a tv, if I cannot turn off the soap effect.
Seems that I missed something there.
Never noticed that on my previous 8-40.
But maybe that is just me ;-)
Millemissen:Seems that I missed something there. Never noticed that on my previous 8-40. But maybe that is just me ;-) MM There is a tv - and there is a BV.
I guess hat the op is experiencing this on all sources and thought that the game mode could help.
I never used game mode on my 8-40.
Actually I think, that the picture is quite well.
I only replaced it to get a bigger and never (BSys4-based) tv....
....not because I disliked it.
Master123456789: How do I get rid of the terrible soap effect on Beovision 8-40? Game mode helps, but it still are there. Any other things you can do?
What source are you using?
Never noticed a soap effect... might be your source....?
Ralf
Press the MENU button on the remote control to get into the ‘Setup Menu’. - Place the cursor on OPTIONS. Press RED button and within 3 seconds press GO.
Turn off FILM MODE in the adjustments menu!
Simpl.
BS A1 2nd gen, BS 1, Beo 1, BL 2, BeoCom 2, 2x LC 2, Form 2, BS 2, Beosound 2, Beplay M3, 2x BS 3, BS 4, 2x Beo 4, BS 5 + CD rip, BM 5, BL 5, BL 6000, Beo 6, BS 6, H6, BL 8000, 2x A8, BV 8-40, H9, 3x A9 Keyring, BL 12 - 3, Serenata, BeoTime, BeoTalk 400, B&O Bottle Opener, BV Eclipse 55 My LEGO
Alen:Press the MENU button on the remote control to get into the ‘Setup Menu’. - Place the cursor on OPTIONS. Press RED button and within 3 seconds press GO. Turn off FILM MODE in the adjustments menu! Simpl. BS 1, Beo 1, BL 2, BeoCom 2, 2x LC 2, Form 2, BS 2, 2x BS 3, BS 4, 2x Beo 4, BS 5 + CD rip, BM 5, BL 5, BL 6000, Beo 6, BS 6, H6, BL 8000, 2x A8, BV 8-40, 3x A9 Keyring, BL 12 - 3, Serenata, BeoTime, BeoTalk 400, B&O Bottle Opener, BV Eclipse 55 My LEGO
elephant: Do you know what determines which mode it is in ?
No, I don't.
elephant: My AUTO seems to always default to GAME MODE regardless of source and content ...
I suggest you to turn off GAME and FILM MODE
Master123456789:Game mode is always on. Helps a bit. Is there a film mode on a bv8-40? Where?
Ok here we go again.
- Press the MENU button on the Beo4 remote control to get into the ‘Setup Menu’.
- Turn off FILM MODE in the adjustments menu!
Thank you, I think it worked to take off the film mode. I have tested it today. :)
Master123456789: Thank you, I think it worked to take off the film mode. I have tested it today. :)
Kind of ironic that the film mode makes the TV so much less film like isn't it?
Jeff
yes very much, - I have also thought about that :)
