What is going wrong here? Any suggestion is much appreciated.
Did you try to connect the BL4000 to another system in the house?
Are you sure that it works?
Yes it works - it is my rear loudspeaker in the main system.
Rolli: This happens both, when using beo 4 and/or the ir eye of the active module. What does this mean? What type nr. is the active? 1616? 1636? What is the Software Version? What command do you use to activate the active? A.AUX? TV? DTV? Ralf Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), no Subwoofer. Screen: Sony KD-85XH9096Dining Room: Beosound Essence MK II with Beolab 4000 on stands, fed by Amazon Echo Show 8Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 1 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55Home Office: Beosystem 3, Beolab 7-4, Beolab 5000, Screen: Sony KD-55XH9005 on Beovision 7-40 stand, ML to Beosound 9000 MK3 and Beosound 5/Beomaster 5 (1 TB SSD version)Bedroom: Sony KD-65XH9077, Beosound Essence MK II with Beolab 6002 and Beolab 11 (all white, wall-mounted) In storage: Beolab 5000/Beomaster 5000 (1960s).
It is a 1636 with sw 1.6.
activation beo 4: Radio (BC2)
activation ir: „Play“
Are you sure, that you have used the PL output to connect the BL4000 (and not the PC input)?
Yes - it is connected to the pl socket.
Good idea Ralf, i will see if I can find an adapter for my phone and check PC Input tonight.
For the time being: Is there a special sequence how to power up the system (e.g. TV first and link room thereafter ... or power up active first and plug in masterlink thereafter .... or something else?)
Also: i joined the masterlink „like for like“. I somehow remember that zwo wires could (should ?) be joined together: pink and white/blue. Could this be a the problem?
Thanks for your support.
You know that you’ll need a special cable for this - not just an ordinary 5-pin DIN adapter!!!
I understood that you already have a ML network running
and
if the ML-plug works for a BS2000, it is not likely that the fault is in the ML connection.
Ciao Millemissen, i tried with the adapter I had and yes: I can play Music from my phone via the „PC“ Socket and contol e.g. the volume with beo 4.
That seems to work ... Andy ideal?
Regarding the ML: yes the Beolab 2000 is working at this Plug. I only thought mabe the active is somehow different ...?...
Ciao Ralf,
i did the following: i connected the Beolink active to a Masterlink socket that we use in the Garden in Summer Time with Beolab 2000.
Voila: it worked and was fully operational. :-)
However in the link room it does not. Strange: Beolab 2000 works but active module not.
Tricky. What can I do?
mmh
Dear all,
i have no idea how to proceed. Does anybody have a clou?
My current assumptions are
- Beolink active with all connections and cabels work (at the ML Plug für Garden, but not at the ML Plug intended in the linkroom)
- Beolab 2000 works fine at the Garden ML Plug and at the linkroom ML Plug
what can i do in order to make the Beolink active work at the linkroom Plug ?
kind rGeradstich
