Serial number number when sticker is gone?
This post has 4 Replies | 0 Followers
Beoberg
Odense, Denmark
Posts 315
Beoberg Posted: Sat, Mar 3 2018 9:25 AM
Hi BeoWorlders
Is there a way to tell a serial number on a B&O product when the label is gone/torn off? Maybe it is possible to track the serial number from a partnumber?
Best regards,
Frederik
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
November35
Posts 52
Serial number is repeated on 3 differente place of each Beolab. For ex in Beolab you can found near connection, under the pot cover of lens and inside on lower section of case. In beolab 6000 near connection or upper the first woofer (depend of serial),inside the case and the rear of little plsatic cover of ampli.
What beolab do you have?
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Sat, Mar 3 2018 9:49 AM
It is a set of BeoLab 9
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Sat, Mar 3 2018 12:52 PM
I have taken the back part off now. I cannot locate it inside the case or on the PCB Confused Could you point to where specific I should look?
Rob - Danish AV
Melbourne
Posts 376
Beolab 3 has it inside the Accoustic lens, perhaps the BL9 does too?
Page 1 of 1 (5 items) | RSS
