I replaced the belts of the cassetteplayer. It works good, only the playing speed is to fast. How can I adjust the speed?
You set the motor speed through the small hole at the top of the motor.Use a thin flad-bladed screwdriver.
Thanks Martin,
Can I do that while the motor is working?
Yes.- Else it would be very difficult to get it right.
