Can any one advise how to dismantle a Beo1 remote (the one that came with the Beovision 1 TV). I have unscrewed the main screw (to access the battery compartment), and also removed the 2 star screws which were beneath the sticker but not sure how to proceed further.
Many thanks
Ian
Some of the text here may help but sadly the photos are missing: https://archivedarchivedforum2.beoworld.org/forums/p/34291/282837.aspx#282837
Since the disassembly procedure is settled...
What is the trick for putting it back together again? I realize the red plunger support need to be rotated, but in that process, the "UP" key on the opposite side always gets stuck... any hints?
Besides... the procedure for programming, the BEO4 mode in the old thread is not entirely correct... There seems to be a specific sequence to get the triple press just right.
