Hi Guys,
Got a Beolab 7.1 with damage on top, Deep scratches on the left side, has anyone repaired such damage? (this is for the experts)
Would like to post a photo but cant see how.
Thanks Ken
Fill them with silicone, sand down the silicone, then spray with plastidip.
Is pastidip a product, who makes it ?
Thaks Ken
Found it on the Internet , any tips when applying?
Clean surface. Let layers dry between. Plastidip is very forgiving :)
Thanks for the help
Ken
Do I have to get special Silicon from the DIY store?
What grade of sandpaper?
How do I prep for spraying,?
Do I only spray the efected area or do i have to spray the whole speaker?
Is there a special coulor og Plastdip you use?
Can you give step by step instructions, as I am keen to get started, but afraid of ruining the speaker.
best wishes, Ken
Any other expers that have done this ?
