Beocord 5500 Power going off Fault
Chris
Australia
Posts 26
Silver Member
Chris Posted: Thu, Mar 15 2018 7:31 AM
Hi
I've fitted new belts to a Beocord 5500 that I bought which has been working great.  The sound is quite impressive for a tape deck and I think at some time the caps have been replaced.  The unit has been working great for the last three months without any issues.
Recently it has developed a fault and nothing obvious seems to be wrong.  It suddenly loses power whenever you press play, forward or rewind and other functions.  It comes on again straight away when pressing the buttons but doesn't stay on for very long.
It doesn't seem to loose power when you repeatedly open and close the tray. But one you stop doing that  it will go off.
Does anyone have any ideas before I have to take this to a repairer?
Cheers
Chris
Page 1 of 1 (1 items) | RSS
