Dvd problem with Avant 32 DVD
Thomas
Norway
Posts 60
Thomas Posted: Sun, Oct 14 2012 10:28 AM
Hi guys,
My avant 32 Dvd shows "blocked !" On the tv display whenever i try to start a dvd.
The dvd tray opens and closes as normal.
Any ideas?
br
Thomas
Format 0  😀😎
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Sun, Oct 14 2012 8:57 PM
I don't remember encountering this on an Avant, but the DVD1 has a parental block that can be set in the options that would cause a similar effect. DVD1 requires a PIN to deactivate the lock. I think the Avant had Philips or Panasonic DVD mechanisms that may have a parental lock or block in the software even though it may not appear in the options. Could also be a country code recognition fault. All speculation on my part ...... ! Graham
Thomas
Norway
Posts 60
Thomas replied on Sun, Oct 14 2012 9:09 PM
Hi and thx for your inputs.
i dont think it has a parental lock at least i have not found it and i have been looking around in the service menu as well.
i did "region free" it.  Any way i can "reset" back to region 2?
btw i have a Avant dvd MK2, not sure if it has the Panasonic or Phillips dvd drive.
br
Thomas
Format 0  😀😎
Page 1 of 1 (3 items) | RSS
