Hi!
I need to get into the service mode on my me6000. I have opened the back and looked around but I can’t find the pins. Hopefully someone can guide me in the right direction.
Follow link for picture - https://imgur.com/a/8vq2a
So maby someone could tell me if the service manual for this unit is found on these pages..
thank you.
I just checked but the ME6000 service manual does not appear to be on this site. There may however be similar models listed that have the same or similar design that may be of use. I do notice e.g. that there are User Manuals listed for the LE6000, and there is both a User Manual and a Service Manual for the LX6000. Unfortunately I can't tell you if those manuals contain the information you are looking for though, but it may be worth trying.
ME6000 (and LE6000) is based on a Philips chassis and has very little in common with the rest of the MX series, except for the external shape. I don't think it has the same service mode (or pins) anywhere.
--mika
