Assigning fixed IP address for Playmaker
This post has 4 Replies | 2 Followers
nickfiore
Posts 3
nickfiore Posted: Mon, Mar 19 2018 12:55 PM
I have recently moved and simultaneously changed routers to an "all in one" box offered by the Altice, the company that took over Cablevision.  I use a (very) old iPad in a BeoPlay A3 and that works fine, however when I try and use my BeoLab 8000s connected to the Playmaker, I get about :60 seconds and then the whole thing shuts down.
As I can't think of anything else to try, I want to assign a fixed IP Address to the Playmaker, but have no idea how to do so.
Any thoughts from anyone would be appreciated.
Thanks.
Ulrike
Germany
Posts 174
Ulrike replied on Mon, Mar 19 2018 2:26 PM
first you need the Playmaker's MAC address:
Open B&O app =》Configure Playmaker =》 Info =》 Status =》 there it is.
Sign in to your router's interface.
Next steps are somewhat more complicated, so I recommend watching the following tutorial (for all O Systems and routers) making it easier:
https://youtu.be/8UhiORc5QAc
Once you have done it the first time, you will find it's easy.
Ulrike
nickfiore
Posts 3
nickfiore replied on Tue, Mar 20 2018 1:14 PM
Ulrike, Thank you.  For any others with same/similar problems note that, in the end, I discovered that my particular router offers a choice of several different channels.  By switching channels to one less susceptible to interference, I solved the problem without resorting to designating a fixed IP address.
nickfiore
Posts 3
Ulrike
Germany
Posts 174
Ulrike replied on Tue, Mar 20 2018 1:30 PM
Thumbs Up Really good! Smile
Page 1 of 1 (5 items) | RSS
