Echo on networklink
This post has 10 Replies | 0 Followers
Beoberg
Odense, Denmark
Posts 315
Beoberg Posted: Tue, Mar 20 2018 12:40 PM
Hi guys
I just bought a M5 to connect to my Eclipse. They are in the same room but aprox. 10 meters away from each other. I set everything up and pressed join on the M5 only to have massive echo. I have been in the network delay option on the Eclipse and set the delay to 30 ms (lowest possible) but still get an awful delay. What am I missing?
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Fl_ip
Posts 160
Fl_ip replied on Tue, Mar 20 2018 2:21 PM
Set wired to 200 and wireless also to 200
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Tue, Mar 20 2018 9:23 PM
That did the trick. You are an angel! Lets have a Party !!!
Master123456789
Posts 237
Interesting - must try that with my Beolink ML/NL converter and my BV11. The sound from the tv is delayed
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Wed, Mar 21 2018 6:32 AM
Well yesterday I thought it worked - maybe I just wanted it to work so badly Whistle It still has echo. The sound from the television is just slightly ahead of the M5. Is it possible to delay the sound from the television to compensate?
tigerisak
Posts 124
tigerisak replied on Wed, Mar 21 2018 7:30 AM
I have the same issue on my Beovison Eclipse connected to Beosound Shape.
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Wed, Mar 21 2018 8:19 AM
I have forwarded the problem to Bang & Olufsen support. Maybe you should do the same? If there is no solution at the moment they have to solve it.
Stan
Chicago-area USA
Posts 869
Stan replied on Wed, Mar 21 2018 2:15 PM
Is it just the TV audio that "echos", or does all audio echo?
It is my understanding that the TV audio "echo" is "as designed".  If you delay the audio playback on the TV, then the sound will no longer be synched with the picture so now you need to "delay" the picture as well.  Music sources that originate from the sound center (Deezer, Spotify, Bluetooth) should be synched.
Stan
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Mar 21 2018 6:27 PM
I have 50 milliseconds for cable and 100 milliseconds for WiFi.
Have only NL stuff including BV11 and Moment.
Master123456789
Posts 237
eh, don't understand - makes no sense that tv sound is delayed with purpose. Or do I understand you wrong? :)
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Sun, Mar 25 2018 9:10 AM
Strangely it has been working flawlessly for the last couple of days. Set to 30/30 milliseconds. Fingers crossed it will stay this way Whistle
Page 1 of 1 (11 items) | RSS
