AURALIC Aries Mini vs. B&O Core
This post has 10 Replies | 1 Follower
integra42
Posts 3
integra42 Posted: Wed, Mar 21 2018 4:23 PM
Hello,
Currently, I'm using an AURALIC Aries Mini which is attached via TOSLINK to my Beolab 18 speakers.
Since the AURALIC lacks Spotify support, I'm thinking about buying a B&O Core.
Is it possible to adjust Bass and Treble values of the Core by using the B&O app ?
Best regards,
Ruediger
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Mar 21 2018 6:48 PM
I thought the Mini supported Spotify Connect?
Jeff
andybandy
Posts 164
andybandy replied on Wed, Mar 21 2018 7:00 PM
Yes Ruediger, you can adjust bass and treble in beosound core:)
andybandy
Posts 164
andybandy replied on Wed, Mar 21 2018 7:06 PM
Sorry for so many same answear, hope the administration her can delete all the duplicate.
I dont know how to delete them
trackbeo
Posts 644
trackbeo replied on Wed, Mar 21 2018 8:35 PM
Jeff:
According to Auralic's website, neither Aries nor Mini lists it in the specifications.
BUT according to John Darko, they both now support it:
https://darko.audio/2017/12/surprise-auralic-add-spotify-connect/
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Mar 21 2018 10:55 PM
My friend who has one told me it had Spotify Connect, so I was puzzled. I have to say, Auralic's website is awful. It's hard to find out info about the products, and I couldn't easily find a way to download any manuals for the Mini. I'm seriously thinking about a Mini since it supports adding a HD so I won't have to worry about a PC being up and running to use my iTunes. My friend is very satisfied with his.
Jeff
koning
holland
Posts 4,220
koning replied on Thu, Mar 22 2018 5:54 AM
Bluesound node II streams everything.
Works perfect!
And a great support.
Sweden
Posts 357
Silver Member
Martin replied on Thu, Mar 22 2018 10:23 AM
I have a Auralic Mini and an Auralic Aries. All I can say is that both these devices has a very good soundquality and the Lightning DS-app is extremly good. Spotify Connect is supported for both devices since 2 month ago. I have tried it and it works perfect.
For me it is hard to see that the Beosound Core is as good as the Auralic Mini. Both have the same cost but the Auralic Mini (and all their products) is real High-End and very well supported with very good and stable software and hardware. The only positive thing with the CORE is that You will get nice integration with B&O:s televisions and loudspeakers.
Best Regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
integra42
Posts 3
integra42 replied on Thu, Mar 22 2018 2:51 PM
Spotify Connect is supported by the Beta firmware only as it is not yet included in the official firmware.
Besides, it still seems to be a bit buggy - especially the volume control does not alway work as expected.
integra42
Posts 3
integra42 replied on Thu, Mar 22 2018 2:58 PM
Does the Core also have a loudness function which can be toggled by the App ?
digi
Bremen
Posts 75
digi replied on Thu, Mar 22 2018 5:35 PM
Yes, it has a loudness function which can be toggled by the app.
BV 14-55 mit BL 18, BL 8000, BL 2, BeoRemote One-BT, ATV 3; BS 9000 & BS Core & BS 4500 mit BL 12-3, BL 12-2, BeoLink 1000; BeoLine mit BC 2, BC 6000; BS 8; BeoVox CX100; BeoTime (analog), BeoTime (digital); Earphone A8; Beoplay H3 + P2
Page 1 of 1 (11 items) | RSS
