Hello all,
I have an issue that sometimes when playing back a bluray disc the voice of the actors are really realy quiet; the music and sound effects are loud and clear. To fix this I have to turn of the Beovision 4 and turn it on again. Then the voice is back to normal. I have the following set up
Beovision 4 65 hooked to a BeoSystem 3 with following speakers
Beolab 7-1 (middle)
BeoLab3 (front left and right)
Beolab 6000 (back left and right)
Bluray Samsung BD8900 hooked up through HDMI
Has anybody experienced the same? Would be good to know what the issue is.
Thanks for any pointers!
Kind regarsd
Roman
Hi athlon007
What is the type number of you BS3, I had similar issues with the 7-40 MKIII early issue software.
Flipping the HDMI inputs with the remote would fix it though.
Hello BEOVOX141,
The type number is 6891
Thanks a lot
