BeoNut since '75
Nice that you are lucky Elephant... on my side everything works without problem only with the first 1.7 beta. The last beta is completely unusable : it almost always says “no product”, so it’s impossible to control anything. Luckily it’s possible to downgrade the version on TestFlight. I’m amazed that every time something new is added, an older thing is broken. That’s not correct development.
diisign.com
ngnear:I am seeing the same symptoms. „No product“. However it is possible to start music or radio from the menu. In the lockscreen the controls are available. Tim
