I'm sure this has been answered before buti can't seem to find it, so apologies.
Does the RL 60.2 have rubber surrounds on the woofers or are they foam that would likely be rotten? I've seen a pair at a reasonable price.
Thanks.
Jeff
Jeff,
Definitely not foam..
Cleve
Confirmed, no problems there - and very nice sounding speakers. And old pair would deserve fresh capacitors in the crossovers, though.
--mika
Thanks! Watching a pair now, should be able to get them, sans stands, for a bit over $200 US. Some scrapes on the side, but appear to be generally OK.
It is worth replacing capacitors on the cross-over though. Brightens up the sound nicely.
Peter
Definitely worth having. I strongly support the re-cap. I was very surprised after I recapped a set - I didn't know RLs could sound so good!
Beo4 'til I die!
