Beogram turntable 6500 string needed and tone arm sloppy HELP
This post has 5 Replies | 0 Followers
-c
Seattle
Posts 40
-c Posted: Mon, Mar 26 2018 2:51 AM
This forum has been great!
I've tried and tried to adjust my 6500 tonearm but it still misses the correct position coming up short when it drops and ends up slipping off the album.   Also there is a lot of slop in the tonearm, it moves too freely side to side.  Please, any advice is appreciated
I have  3 turntables, one aforementioned, the other is for parts and the third is missing its string.  I would  be indebted to you if you can provide the correct source for the turntable string.
Thanks much
It's a fine line between collecting and hoarding, and I'm always dancing on it.  Beomaster 8000 x2, Beocord 8004, Beomaster 6000, Beocord 9000, CDX, Beomaster 6500, Beocord 6500, Beogram 6500 CD, Beogram 6500 Turntable, BeoSound 2300, BeoSound 2000,  BeoLab 8000, BeoLab 6000, BeoLab 2 Sub, BeoVox S45.2 x4, BeoVox S75, BeoVox S120, BeoVox M150,  BeoVox MS150, RL140, BeoTime, BeoCom 1
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Mar 26 2018 6:06 AM
pcaloia:
Thanks much
The tonearm needs to move freely approx. 1cm each side. The reason you cannot adjust it correctly, might be that the white plastic holder, where the 2 ends of the wire is connected to the sledge, is broken, and now sits loose. It is a common problem, and you just break it off, and then replace it with a small bolt with nut and washers on each side, and then slide the spring down on that insted of the original white plastic tap.
/Jacob
W.Frankenberg / Gandalf
Heilbronn / Germany
Posts 290
hi
have a look  at this older post
View this post at https://archivedforum2.beoworld.org/forums/p/14862/130974.aspx#130974
here you can see the damage of the wire holder.
please ask Martin (Dillen) for a replacement for the rope sometimes he has something in his "dungeon"!Cool
wilfried
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Mar 27 2018 2:55 PM
And we kindly ask members to upgrade to minimum silver membership level to place sales and wanted ads.
All support is appreciated to keep this site running.
-c
Seattle
Posts 40
-c replied on Tue, Apr 10 2018 8:44 PM
Thanks everyone, duly noted on the membership upgrade I'm now silver
-c
Seattle
Posts 40
Page 1 of 1 (6 items) | RSS
