Beogram 4002 NOISE!
This post has 12 Replies | 1 Follower
Piaf
Victoria, British Columbia Canada
Posts 2,639
Piaf Posted: Sun, Oct 14 2012 11:23 PM
My Beogram 4002 began making some rather odd noises and I felt lubrication and/or belt change was in order.
I ignored my better judgment to stop using this turntable until I could have a look at it and as punishment for my lack of proper concern the 4002 crapped out on me at the end of play. No pickup and no stop after reaching the rest position.  Angry
Opened up the 4002 and everything looked in order until START was pressed…. what a lot of racket this turntable made! Such a lot of fuss over nothing, a tempest in a teapot if ever there was one. The wheel which receives the belt to move the tonearm had come loose and was out of position.
Once back in position and the retaining screw tightened end of problem.
Since I was in there I dropped a bit of lubrication in all the appreciate spots and the 4002 is happy as a clam once again.
FINALLY a simple B&O fix. Hallelujah! Lets have a Party !!!
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century,  S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase,  B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sun, Oct 14 2012 11:30 PM
Great to hear Jeff that everything turned out fine!
Brengen & Ophalen
Søren Mexico
Mexico City
Posts 6,411
Leslie:
Good job finding the failure, but you said that you oiled it a little, I really hope that you did some cleaning too, as it was open, if not, I may be a little disappointed.Smile
Piaf
Posts 2,639
Piaf replied on Mon, Oct 15 2012 12:08 AM
Hi Søren,
It would be an awful thing to disappoint you, and I sincerely hope I don’t, but I gotta ask, clean what? This is MY turntable so you have to know there is no dust, no debris.
Yes shortly after I first received this turntable I went inside with a paint brush and vacuum being the tidy-freak that I am. Hey, I am clean, what can I tell ya? Embarrassed
Now maybe there is something more serious that you feel needs attention and if so, let me know and I’ll attend to it.
By the way this is my temperamental turntable forever needing adjustments…. which never seemed to end. My Beogram 4004 has never required a single adjustment, just a replaced belt. But the 4002 always had something wrong, pickup or arm drop in the wrong place, arm too heavy then too light. It went on and on for a couple of years.  Devil
Then like a miracle, the last adjustment held and the 4002 has not needed attention since….. at least 3 years. So today’s tiny adjustment seemed like “old times” but in a positive way. The poor old thing needs me…. and we all want to be needed. Smile
Jeff
Bob
Charente, France
Posts 418
Bob replied on Mon, Oct 15 2012 12:16 AM
Well done you ;) Wink
hope you'd have horror free week full of joy
bob
Piaf:
Jeff
Don't worry - be Happy
Søren Mexico
Mexico City
Posts 6,411
Thank you for enlightening me, I will never ask againBig Smile, Your 4002 just wanted to be absolutely sure that i came to a good home, this last failure was just because it was feeling alone, you concentrated and working with your amps and speakers.Whistle
Piaf
Posts 2,639
Piaf replied on Mon, Oct 15 2012 3:20 AM
Hi Søren,
For goodness sakes, you can ask me anything, in fact, I wish you would. Who knows what I might be missing? Unsure
It is just I had assumed that folks knew that I am a detail guy. I clean out my computers regularly and I certain do the same when I open up a B&O product, as most are impossibly difficult to get into…. And then back together.
Speaking of which a 1” square clear plastic piece fell out of my Beomaster 4400 when I opened it up. Any idea where it is supposed to go?  Confused
As for the Beogram 4002 feeling neglected, I suspect that you are right. All the other pieces were getting the attention and the Beogram felt neglected and perhaps unloved.
Perhaps it is aware it is not my favorite Beogram, but it most certainly isn’t my least favorite. That distinction rests with my Beogram 1602, which does nothing wrong, but just isn’t in the same league with the others. For the record my next least favored Beogram is the 8000, but its mine, and I cobbled it together from two 8000’s.
In any case now both Beomaster 2400 and its buddy, the Beogram 4002 are clean inside and out, and working well.
Jeff
Søren Mexico
Mexico City
Posts 6,411
Piaf:
I wont ask about cleaning but everything else. The plastic piece goes below the cables, protecting cables for solder point damages, it was originally glued to the PCB solder points, its a *** to get in place again and if not glued it will fall out again.
Piaf
Posts 2,639
Piaf replied on Mon, Oct 15 2012 3:56 AM
I will do my best to take care of this, but may I assume, my electronic maven friend, that this protection is not essential to am amp sitting quietly in my dining room?
Jeff
Søren Mexico
Mexico City
Posts 6,411
Piaf:
Jeff
Well it was put there for a reason, and cables tends to move a little when getting hot and cold. If the cables are running free of the PCB nothing happens now, but who knows in 10 years from now,
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Oct 15 2012 6:32 AM
The 1" by1" square plastic piece is glued to the upper side of the power switch metal housing,
This housing sits very near solder joints on the above board and can short to these if the power switch is pressed very hard.
Add a drop of glue to it and push it back in between the power switch and the board.
Søren Mexico
Mexico City
Posts 6,411
Dillen:
Thank you Martin, I found the piece loose under the cables at the red arrow, when I took the transformer out, and it fits exactly in there. A lot easier to get it back where it belongsSmile
Piaf
Posts 2,639
Piaf replied on Tue, Oct 16 2012 3:56 AM
Thank you Martin,
I will put the plastic piece back where it is supposed to be thus averting disaster. Mine just feel out when I was inspecting the Beomaster 4400 and turned it over.
Jeff
Page 1 of 1 (13 items) | RSS
