Having a strange issue with the beosound 5 encore. Im using my encore with a synology NAS which works fine. My issue is however when I delete an unwanted flac album it still appears on the encore although without the album art and unable to play its like a ghost of the album. I have resync the encore with the NAS but the ghost album still appears. Anybody know what causes this and how to solve it.
Regards
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Sometimes you have to secure delete or overwrite the new fee space to prevent the Encore from sensing the presence of deleted data. You can also do a factory reset on the BS5 Encore, which will force it to rescan the entire drive and hopefully not show the deleted content afterwards. I have to do this on mine when I delete or change several albums on the targeted drive.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
To do a BeoSound 5 Encore factory reset:
1) Go to 'mode' > 'settings', but do not press <go>.
2) Now press <arrow right> two times and then press <go>. This opens the service menu in English.
3) Look for the option to "reset to factory defaults" under the "Maintenance" menu and press <go>.
This should reset the Encore and force it to rescan all the data sources.
applemac1:it still appears on the encore although without the album art
B&o
If ♫ then most probable cause is the dlna server. Be sure it doesn't search the bin.
applemac1:Hi All, Nope this did not work reset beosound encore to factory setting rescanned all music from the nas drive after deleting all recycle bins and im still getiing these ghost albums with a music not as a cover.
To my opinion the solution lies within your Synology and the server software within.
