Does any one have for sale a pair of working woofers for the Beovox S45-2?
Keith
Keith : Does any one have for sale a pair of working woofers for the Beovox S45-2? Keith
Magnet problem Keith?
Check this:
https://archivedforum2.beoworld.org/forums/p/23102/193118.aspx
These are easily repaired.....
Famous last words, but I suppose you can’t break what’s already broken.
it’s just jumping into the unknown.
My only problem is the centre cone, if I mess it up can you buy new replacements.
Keith : Famous last words, but I suppose you can’t break what’s already broken. it’s just jumping into the unknown. My only problem is the centre cone, if I mess it up can you buy new replacements. Keith
Keith,
A speaker repair shop can handle this repair job I'm sure. If parts are only separated from each other but not broken, I think your woofers are recoverable.
Trouble is, there’s none that I can find in the UK.
But I would like to have a go first and then the repair shop second.
Check out my posts on this repair..........It's a lot easier than you think. I have a jig for centering the magnet pole in the voice coil.....if you post them to me I will do the job for you, or I can send you the jig....just dont forget where it lives
https://archivedforum2.beoworld.org/forums/t/29423.aspx
try this
Hi Craig
if you don’t mind I will send the drivers over to you. I live near Shrewsbury.
if you PM with your address and cost, that would be great.
What a fantastic job you’ve done.
I see what you mean about the alignment jig.
We dont charge each other for stuff on this site, postage will be the only cost you have to cover, bear in mind they mat not be recovereable but I will do my best.
Craig
I've sent you an email with my address
Craig: Keith We dont charge each other for stuff on this site, postage will be the only cost you have to cover, bear in mind they mat not be recovereable but I will do my best. Craig
I didn't know that.I can't give away parts for free. If I started doing that, I would never see the end of it.Time for me to move on, perhaps.
Dillen:I didn't know that.I can't give away parts for free. If I started doing that, I would never see the end of it.Time for me to move on, perhaps.
I think Craig got a little exited, but I can mention a couple of times where also you gave away parts for free, not to talk about the invaluable help you provide on the forum, so please stay
Parts and hardware are not the same as advice and expertise......parts cost money
