Hi.. my name is Alan and I just purchased my first B&O product, Beoplay M5. It plays very good, but I can’t fix a problem.
When I listen to Music, Spotify via IPad and turn of... the next time I turn on the Spotify, the volume is almost as high as it can be on the M5!
It’ s on WIFI.
Why and what to do?
Alan
Thank you for your reply.
I can not find the volume adjustment in the Beoplay app.
Alyng:Thank you for your reply. I can not find the volume adjustment in the Beoplay app.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
It works :)
thanks.. tack så mycket.
Alyng:It works :) thanks.. tack så mycket.
