Beomaster 4400 tuner awfull sound
This post has 10 Replies | 1 Follower
kbaelden28
Posts 33
Silver Member
kbaelden28 Posted: Mon, Apr 2 2018 9:24 AM
Hey,
Recently I bought a Beomaster 4400. The radio does receive a number of stations and the reception is good  but the sound remains awful, too bad to listen to. Also the stereo indicator doesn't work.
If I connect my Beogram 4002 to it, the sound is great better tegen my Beomaster 3000-2 which Is use every day.
If I replace all capacitors from the tuner section, is this enough or are there other components that require attention?
Kristof
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
I just had a similar issue see this thread https://archivedforum2.beoworld.org/forums/t/30179.aspx?PageIndex=7
Replaced the decoder IC and the variable capacitor, only because the capacitor looked in poor condition and was hard to turn.
kbaelden28
Posts 33
Silver Member
Thanks Craig, very useful thread.
If I replace the IC decoder the stereo indicator will work, if I understand correctly it will also improve sound quality due to a better left and right channel seperation?
Kristof
Craig
Posts 2,040
Silver Member
Craig replied on Mon, Apr 2 2018 8:30 PM
l can only tell you that replacing the IC and variable capacitor sorted my problem, you may have other issues too....however I would certainly replace your IC
Craig
kbaelden28
Posts 33
Silver Member
Hi Craig, where did you buy the ic RCA-CA1310A ? Langrex doesn't have this part in stock.
Kristof
Craig
Posts 2,040
Silver Member
Craig replied on Wed, Apr 4 2018 9:52 AM
Hi Kristof
Send me your address and I will post you one, I had to buy a minimum of 5 when I bought mine so I have 4 left, the cost was £5 for the 5.....so thats £1.00 to you plus postage ;¬)
Regards Craig
kbaelden28
Posts 33
Silver Member
Hi Craig, that's great news. My address is
Kristof Baelden
Constant verhulststaat 48
2590 Berlaar
Belgium
 can you give me your account number? You can also mail it to kristof.baelden@gmail.com
Kristof
Craig
Posts 2,040
Silver Member
Craig replied on Fri, Apr 6 2018 8:18 AM
Kristof
Your IC is now in the post.....let me know when it arrives, postage £2.75 + £1.00 = £3.75............lets hope it sorts your problem out.
Craig
kbaelden28
Posts 33
Silver Member
Great news, send your accountnumber via e-mail and I will wire the funds. Thanks Kristof
kbaelden28
Posts 33
Silver Member
kbaelden28 replied on Mon, Apr 30 2018 12:34 PM
Hi Craig, I just replaced the IC and variable capacitor.
Stereo light comes up. I have very good reception , no distortion and great sound in both channels.
Thanks a lot
Kristof
Please drop me an an e-mail to settle my debt.
Craig
Posts 2,040
Silver Member
Craig replied on Mon, Apr 30 2018 4:56 PM
Great news Kristof.........Sorry for the delayed reply, I have been in Rome soaking up the sights and the Italian wines, I will email my details to you.
Enjoy
Craig
Page 1 of 1 (11 items) | RSS
